f1anatic Posted November 23, 2008 Share Posted November 23, 2008 55W, H7, 4500 or 5000K which one ? http://www.ddmtuning.com/hidkihidbuhi.html DDM 55 Watt Slim Ballast HID Kithttp://us.st1.yimg.com/store1.yimg.com/Img/trans_1x1.gif or Apexcone 55 Watt Full Size Ballast HID Kit Is there a performance difference between them ? I know Apexcone and DDM are 2 brands from the same company. Is there one more reliable than the other ? More affected by heat or humidity? easier to mount (specify location) having slim ballasts with outside ignitors (DDM) vs. a larger module combining the ballast and the igniter. I am upgrading my lights. I am not interested in any other brands since I think these are some of the more affordable yet well established brands - which people use. I have also seen "race" versions of these 2 kits - sold by the Vendor RPM here. What is a "race" kit ? a glorified 55 Watt upgrade over the standard 35 Watt ? Lastly, should I get a dual HID kit to put it on fogs as well ? or maybe for the high beams ? Thanks. Link to comment Share on other sites More sharing options...
urs1ne Posted November 23, 2008 Share Posted November 23, 2008 I got the Apexcone 55w 5000K kit and its great and bright but if I could do it all over again I would either go retro fit or just get the Phillips OEM bulbs. I have had to replace my bulbs about once a year so far. ^ n00bs below this line Link to comment Share on other sites More sharing options...
xenon expert Posted November 24, 2008 Share Posted November 24, 2008 55W, H7, 4500 or 5000K which one ? http://www.ddmtuning.com/hidkihidbuhi.html DDM 55 Watt Slim Ballast HID Kithttp://us.st1.yimg.com/store1.yimg.com/Img/trans_1x1.gif or Apexcone 55 Watt Full Size Ballast HID Kit Is there a performance difference between them ? I know Apexcone and DDM are 2 brands from the same company. Is there one more reliable than the other ? More affected by heat or humidity? easier to mount (specify location) having slim ballasts with outside ignitors (DDM) vs. a larger module combining the ballast and the igniter. I am upgrading my lights. I am not interested in any other brands since I think these are some of the more affordable yet well established brands - which people use. I have also seen "race" versions of these 2 kits - sold by the Vendor RPM here. What is a "race" kit ? a glorified 55 Watt upgrade over the standard 35 Watt ? Lastly, should I get a dual HID kit to put it on fogs as well ? or maybe for the high beams ? Thanks. Race is 55W. Same thing. Apexcone and DDM is the same thing except the size in ballast. Although very good for a Chinese made kit, it's still a Chinese made kit and doesn't offer the same reliability as Japanese made brands. Just so you have all the info. You might also want to read this: http://legacygt.com/forums/showthread.php?p=2173912#post2173912 Oliver Link to comment Share on other sites More sharing options...
