kabrons Posted November 20, 2008 Share Posted November 20, 2008 The timing belt just went on my 96 legacy gt. Is the motor junk? If the belt did jump will the pistons hit the valves? The motor turns over but very fast and doesn't start. Help ASAP -- no car no work:eek: Link to comment Share on other sites More sharing options...
jonklein611 Posted November 20, 2008 Share Posted November 20, 2008 I think the 2.5's then were interference engines..... bad news bears possibly, but im sure a shop would be able to tell you. Link to comment Share on other sites More sharing options...
vet Posted November 20, 2008 Share Posted November 20, 2008 I don't think you want to be turning over the motor in this condition. Link to comment Share on other sites More sharing options...
SayingSorry1988 Posted November 20, 2008 Share Posted November 20, 2008 my cam gear broke on mine which made the valves bent so idk dont try startin it bring it to the shop or have one of those people come out to u and do it and see wat they say Link to comment Share on other sites More sharing options...
blackfang Posted November 20, 2008 Share Posted November 20, 2008 If I recall they are interference motors. Best bet is to have it towed in to have a technician look at it. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
Bdubs Posted November 20, 2008 Share Posted November 20, 2008 If you turned it over after the timing belt snapped, you may have ruined some valves or trashed a piston. Link to comment Share on other sites More sharing options...
bushbelay Posted November 20, 2008 Share Posted November 20, 2008 With the subby you have a better chance of only bending a valve (or two), not as much piston damage. However, anything is possible! Good luck. How long had it been since you changed your timing belt? Link to comment Share on other sites More sharing options...
caschmidt Posted November 20, 2008 Share Posted November 20, 2008 How many miles are on it?! mine has 125k and has not been done yet... now im really scared Yes, the ej25 IS an interference engine, unfortunately Link to comment Share on other sites More sharing options...
jonklein611 Posted November 21, 2008 Share Posted November 21, 2008 How many miles are on it?! mine has 125k and has not been done yet... now im really scared Yes, the ej25 IS an interference engine, unfortunately I would change it, AND the tensioner. Luckly the 2.2 isn't, cause i lost a tensioner. Link to comment Share on other sites More sharing options...
kabrons Posted November 21, 2008 Author Share Posted November 21, 2008 I was fueling up, when it happened. It sputtered then died so I didn't even think "timing belt" that's why I tried to start it. But when it turned over quickly I knew what happened. I bought the car USED with 145K miles. I kick myself because it was running rough a month ago and asked the previous owner if he ever had the timing belt replaced. Obviously the answer was a resounding NO. Anyway, I've begun the repair process with the help of a mechnic friend. I appreciate all the replies to my post (even if it wasn't what I wanted to hear). Link to comment Share on other sites More sharing options...
caschmidt Posted November 21, 2008 Share Posted November 21, 2008 Well, I am in college in NH right now, I have to drive about 400 mi home to PA... lets hope it last me Link to comment Share on other sites More sharing options...
SLegacy99 Posted November 21, 2008 Share Posted November 21, 2008 Well, I am in college in NH right now, I have to drive about 400 mi home to PA... lets hope it last me I can sympathize with you. Link to comment Share on other sites More sharing options...
987687 Posted November 21, 2008 Share Posted November 21, 2008 Does the GT have a 2.5? Because that is interference, I know someone with the 2.5 have their belt go. It was not pretty. The 2.2 is not, my belt just went, and the engine is fine. Link to comment Share on other sites More sharing options...
caschmidt Posted November 22, 2008 Share Posted November 22, 2008 Does the GT have a 2.5? Because that is interference, I know someone with the 2.5 have their belt go. It was not pretty. The 2.2 is not, my belt just went, and the engine is fine. Do you know at what mileage that their timing belt went? Link to comment Share on other sites More sharing options...
987687 Posted November 22, 2008 Share Posted November 22, 2008 Do you know at what mileage that their timing belt went? 180,000, that was the first time they replaced it. Link to comment Share on other sites More sharing options...
jonklein611 Posted November 22, 2008 Share Posted November 22, 2008 Mine went (tensioner failed @ 100k) but we had replaced the belt before that, that's why i preach changing the tensioner at the same time. Link to comment Share on other sites More sharing options...
Silverstar Posted November 23, 2008 Share Posted November 23, 2008 The belt change is really easy, no reason not to do it at 100k miles or as recommended for the older engines. Guess this doesn't help the OP, but others with hi mileage should take note. Link to comment Share on other sites More sharing options...
bushbelay Posted November 24, 2008 Share Posted November 24, 2008 I would change it, AND the tensioner. Luckly the 2.2 isn't, cause i lost a tensioner. I have the 2.2 and I changed my timing belt a month or so ago. My old tensioner was 'wet', like it was leaking. I am glad I ordered a new one with all my parts! Link to comment Share on other sites More sharing options...
jonklein611 Posted November 24, 2008 Share Posted November 24, 2008 Yeah, mine apparently sheared off the block..... Link to comment Share on other sites More sharing options...
987687 Posted November 24, 2008 Share Posted November 24, 2008 I have the 2.2 and I changed my timing belt a month or so ago. My old tensioner was 'wet', like it was leaking. I am glad I ordered a new one with all my parts! Your engine is non-interference anyway, so it would not matter if you belt broke. I'd suggest doing your water pump at the same time. Mine froze up and broke the timing belt. It went at 92,062. non-interference FTW! Link to comment Share on other sites More sharing options...
jonklein611 Posted November 24, 2008 Share Posted November 24, 2008 Your engine is non-interference anyway, so it would not matter if you belt broke. I'd suggest doing your water pump at the same time. Mine froze up and broke the timing belt. It went at 92,062. non-interference FTW! I think it would matter if my belt broke.... I'd rather not be stranded in some random place cause my timing was gone. Good idea on the water pump too. Link to comment Share on other sites More sharing options...
987687 Posted November 24, 2008 Share Posted November 24, 2008 I think it would matter if my belt broke.... I'd rather not be stranded in some random place cause my timing was gone. Good idea on the water pump too. Well yeah, I meant matter as in engine damage. Mine mattered as in get stuck in random place. My pump seized when I was 3 hours away from home in northern Maine at night. You can bet my mom was happy to come pick up my friends and I. Then my car was also at a dealer 3 hours away from home, gigantic fiasco. GET IT DONE NOW, haha. Link to comment Share on other sites More sharing options...
caschmidt Posted November 24, 2008 Share Posted November 24, 2008 yupppp i finally set up an appointment for this wednesday... now all I need to do is make it 400 mi home!!!! I got the belt, water pump, tensioner, and all appropriate seals. Thanks for ur posts! ill let u know what happens Link to comment Share on other sites More sharing options...
caschmidt Posted November 30, 2008 Share Posted November 30, 2008 I got all the parts- belt, tensioner, water pump, gaskets & pulleys, thermostat... I think that is it. Total for that entire job I ended up paying a little over $900 AND the check engine light came on on the way home. Turns out I need a new catalytic converter!! The dealer tried to charge me $2300 . Luckily my brother can get me a cat for $240. Phew! Link to comment Share on other sites More sharing options...
987687 Posted November 30, 2008 Share Posted November 30, 2008 I got all the parts- belt, tensioner, water pump, gaskets & pulleys, thermostat... I think that is it. Total for that entire job I ended up paying a little over $900 AND the check engine light came on on the way home. Turns out I need a new catalytic converter!! The dealer tried to charge me $2300 . Luckily my brother can get me a cat for $240. Phew! $2300 for a cat converter? That it ridiculous! Link to comment Share on other sites More sharing options...
