peteyjr Posted November 20, 2008 Share Posted November 20, 2008 Currently running a version 2 Progress rear bar 22mm. Pretty happy with the improvement in handling. Was wondering about doing the front bar now . I had the Cobb front and rears on my WRX. My understanding is the front bar is not really needed. Has anyone done the rear bar first and then gone on to do the front bar? Worth it. Currently running Swifts on stockers but looking to improve handling a bit more. Link to comment Share on other sites More sharing options...
caramall2 Posted November 21, 2008 Share Posted November 21, 2008 Depends on what you're after. I installed rear first...really liked it, then added front and liked that as well (just a little less body roll). Does that mean it actually handles better now? Not necessarily. Remember increasing the front bar generally increases understeer. So, I like having both front and rear, but again, not absolutely sure it's increased grip. It does make it more "solid" feeling. I like to experiment (why I also got coilovers so I could play around with settins) so I'd say...get it, try it, if you don't like it then sell it. Link to comment Share on other sites More sharing options...
Th3Franz Posted November 22, 2008 Share Posted November 22, 2008 camber-challenged cars, like ours, actually benefit a lot from stiffening the suspension. Keep in mind the front suspension is a MacPherson strut setup and the wheels' camber goes positive under hard cornering, resulting in understeer. It was my experience that adding a front and rear sway bar kept the car very neutral and the front bar helps turn in and reduces understeer because it offers a better dynamic camber curve with the MacPherson strut. I think it is very worth it to improve handling. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
