Saul_Good Posted November 19, 2008 Share Posted November 19, 2008 I hate washing bug guts off cuz it takes forever. Is there something out there (pad, spray, wax, etc) that will make this job a bit easier? Link to comment Share on other sites More sharing options...
c-lo Posted November 19, 2008 Share Posted November 19, 2008 you can search the the detailing forum and check out Ocdetails threads. but I'll tell you I've been using turtle wax bug and tar remover spray and I found it works well.! You can set your spray pattern and apply, let it sit and buff off. http://www.turtlewax.com/main.taf?p=2,1,4,11 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Regal05LGT Posted November 19, 2008 Share Posted November 19, 2008 +1 for bug and tar remover, works great Link to comment Share on other sites More sharing options...
OCDetails Posted November 20, 2008 Share Posted November 20, 2008 Yup, that stuff is the bomb. Something else that works well in a jam is just to presoak the bugs with something designed for cleaning anyway. Again, only for when you are in a jam, but I've had success spraying them with Invisible Glass and letting that soak in. Not as effective as a bug/tar remover, but it helps more than simple water does. I keep some QD, glass cleaner, and microfiber towels in an 'emergency kit' in each of my vehicles and after a road trip where I just need to get the bugs off, this method works great. Another presoaking idea is just to scrub them down with soap. Actually, there was a bucketless car wash that was out for awhile. I think Eagle One made it. It was supposed to be sprayed on the car and then it would foam up and wash the car without the need for a bucket. I found a number of problems with that theory, but the product itself worked great as a bug soaker as well as being mixed with water to make a clay lube. Any really thin cheap car wash would work well for this kind of thing. Just put it in a spray bottle and you've got cheap bug remover helper. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
Danase Posted November 20, 2008 Share Posted November 20, 2008 You are going to want to clean it really well and keep it waxed/sealed really well, especially if it is a big problem. I use Danase Turbo Shine to remove bugs from my motorcycle and helmet all of the time with ease. But I also keep a fresh coat of wax on the bikes and helmets to make the job even easier. Link to comment Share on other sites More sharing options...
