gstreev Posted November 11, 2008 Share Posted November 11, 2008 I just did the fronts, no problem. In the past I have had problems with rears due to parking brake issues and having trouble turning in the caliper pistons. Can the pistons be pushed in with a clamp, do I nedd a special tool or do they have to be screwed in? Link to comment Share on other sites More sharing options...
magnus617 Posted November 11, 2008 Share Posted November 11, 2008 if i remember correctly, mine weren't to bad.i just used a c-clamp and a piece of aluminium angle. never, under any circumstances, take sleeping pills at the same time as a laxative. Link to comment Share on other sites More sharing options...
ilh Posted November 12, 2008 Share Posted November 12, 2008 You can definitely just push the rear pistons in with a clamp. You might want to look at the vacation pix. Link to comment Share on other sites More sharing options...
RustyShackleford Posted November 12, 2008 Share Posted November 12, 2008 Frankly, I've always been able to push the pistons in with firm pressure with my hands - and I don't think I have unusually strong hands (for a guy). There's of course the issue of overflowing the fluid reservoir when you do this - SpeedBleeder users can simply open the bleeder screw on the wheel in question. Link to comment Share on other sites More sharing options...
Spec B Posted November 12, 2008 Share Posted November 12, 2008 Not sure if this helps at all.. 05 - Rear Brake Pad.pdf Link to comment Share on other sites More sharing options...
gstreev Posted November 13, 2008 Author Share Posted November 13, 2008 Not sure if this helps at all.. [ATTACH]59653[/ATTACH] Thanks, do you have anything that shows the rotor removal? Its the parking brake setup that I'm not sure about? Link to comment Share on other sites More sharing options...
RustyShackleford Posted November 13, 2008 Share Posted November 13, 2008 Thanks, do you have anything that shows the rotor removal? Its the parking brake setup that I'm not sure about? I'm a little fuzzy on when I did mine a few years ago, but I remember it being just like the front ones, and the parking brake a non-issue. (That was a MY97). Link to comment Share on other sites More sharing options...
