SubieAA Posted November 9, 2008 Share Posted November 9, 2008 Hi fellow NEders, I have been driving my with my clutch which started slipping about 5 months after I bought it in January. I cad drive it each day, but I am about ready to finally get a new clutch, and I can afford it. I have read about the ACT Stage 1 clutch plus WRX fly wheel. I am stage 1 Cobb with a longer stability bar in the rear. This is my daily driver, I do 60miles minimum a day, and I want to drive the car for a long time. I might go stage 2, but I want to upgrade the brakes first; I have been unhappy with some sudden stops on the highway. So am I better of with an OEM clutch set-up or an ACT clutch plus WRX flywheel? Especially for Mass Greater Metrowest driving conditions. Also who do you recommend for an install. I have used Speen Street SUbaru in Framingham for 30K service. Thanks. Link to comment Share on other sites More sharing options...
CapeStylz Posted November 10, 2008 Share Posted November 10, 2008 dont know if this will help or not but...... i had same sort of thing happen so i replaced the oem clutch but got the lightened fw then i went stage 2.5 (up/dp/cat-back,fmic,typhoon intake tune....now it slips under full throttle and i only put about 20,000 on the clutch...........so im getting an upgraded clutch only 6 months later....which sucks but i didnt think i would mod that soon and now im stuck buying another clutch Link to comment Share on other sites More sharing options...
SubieAA Posted November 18, 2008 Author Share Posted November 18, 2008 What are you upgrading to? Was the lightened fw the problem? Nice car btw. Link to comment Share on other sites More sharing options...
HansGT Posted November 18, 2008 Share Posted November 18, 2008 The ACT will hold up nicely for you and drives very near stock. Maybe 5-10% firmer pedal with nice engagement. You could get OEM and it should be fine at stage 1 depending how you drive. But for the cost you should just go ahead with the ACT. You could also go with SPEC if you want to keep a dual mass flywheel. Personally I've been very pleased with my ACT clutch (SB5-HDMM) and 06 WRX Flywheel (PN: 12342AA090) http://www.legacygt.com/forums/showthread.php?t=55859&highlight=act+win Link to comment Share on other sites More sharing options...
HansGT Posted November 18, 2008 Share Posted November 18, 2008 What are you upgrading to? Was the lightened fw the problem? Nice car btw. Most likely his problem was too much power for the stock clutch. Link to comment Share on other sites More sharing options...
SubieAA Posted November 18, 2008 Author Share Posted November 18, 2008 Most likely his problem was too much power for the stock clutch. I do drive aggresively, so I do put pressure on the clutch. I would eventually like to get to stage 2. I just have to take care of the suspension and brakes first. I have read a lot of good reviews of the ACT clutch plus WRX fw. It sounds like once in awhile they send out a dud and those poor customers have a lot of trouble. Does this combination hold up under stage 2 then? Thanks. Link to comment Share on other sites More sharing options...
HansGT Posted November 18, 2008 Share Posted November 18, 2008 ^ *knocks on wood* Yes. For me anyway...stage 2+. I've had the set up for over a year and no slippage. (UP/TBE/PERRIN TMIC/TDC Stage 2 93 tune) Link to comment Share on other sites More sharing options...
sportwagon Posted November 19, 2008 Share Posted November 19, 2008 I'm in the market for a clutch, too... I've babied it since last fall... and still could for a while longer, but with the colder weather finally here (esp. at night when I do most of my driving) it makes my clutch slip in 5th and now almost in 4th, too... in the summer I really experience almost no slippage! I can drive fine with out slippage most of the time, but I'm getting ready for a busy ski season and lot of mileage... so it's time to ACT. huh huh... I guess I'll go with the ACT... but which stage? Anyone have some suggestions... Link to comment Share on other sites More sharing options...
sportwagon Posted November 19, 2008 Share Posted November 19, 2008 I drive 50+ miles (mostly highway, with minimal traffic) daily. I drive hard, but not much lately due to the clutch. My car (2005 Legacy GT ltd. Sedan) has 79 and change on it. I live in South Boston... and I hate street parking... but that's besides the point! My current mods (I plan to do full TBE at some point): Chassis/Suspension: JDM Legacy STi Sport Spring Set – Pink JDM Legacy GT Bilstein Struts – Rev. A Spec B Aluminum Front Lower Control Arms SuperPro Polyurethane Camber-Increasing LCA Bushings STi Training Arms w/ ball-bearing bushing– Painted Blue w/ Silver STi logos Cusco Front Sway Bar 23mm – Blue Cusco Rear Sway Bar 21mm – Blue AVO Front & Rear Adjustable Endlinks (AVO Solid Endlinks to be installed) Cobb Rear Sway Bar Reinforcement Bracket Kit STi Upper Strut Bar Cusco Front Lower Brace – Blue Cusco Rear Lower Brace – Blue Engine: AVO Bar & Plate Top Mount Intercooler – Red-Painted STi Logo GFB Hybrid Blow Off Valve – Set to 50/50 recirculation Zero Sports Cool Action Intercooler Splitter Zero Sports Intake Pipe Perrin Radiator Hose – Red Perrin Drop-In filter Blitz Induction Cover - Air Box Replacement Samco BOV Hoses – Red (Perrin Lightweight Crank Pulley to be installed) Engine Bay Bling: Cusco Radiator Cooling Plate STi 1.4 Barr Radiator Cap STi Engine Oil Cap Prodrive Battery Tie-down JDM Engine Bay Cover Set – Black Brakes: Painted Calipers – Red DBA 4000 Series Slotted Rotors Front & Rear Hawk HPS Brake Pads Front & Rear Goodridge Silicone-Coated Stainless Steel Brake Lines – Carbon Gray Subaru Brake Fluid Drivetrain: Cobb Double-Adjustable Short Throw Shifter Kartboy Rear Shifter Bushing Kartboy Hardened Shifter Bushings Exhaust: DC Sports Uppipe (not currently installed) Genome STi Axle-back Exhaust Cusco Exhaust Hangars Engine Management: Cobb AccessPort – Stage 1 Audio: Sony MEX-5DI MP3/CD/Memeory Stick Receiver w/ TFT LCD Display Sony CDX-757MX 10 Disc CD/MP3 Changer Sony XA-300 Auxiliary/BUS Changer Control Unit w/ USB Interface JL CleanSweep CL44I dsp JL 500/1 Monoblock Amplifier JL 300/4 4 Channel Amplifier JL 10W7 High Output Wedge Subwoofer Box JL VR 650-Csi Front Component Speakers JL VR 600-Csi Rear Component Speakers JL Remote Bass Control Knob JL XA-PBTC- 2 – Positive Battery Terminal JL XA-NBTC- 2 – Negative Battery Terminal JL XA-BLKPW4- 115 – 4 Gauge Ground Power Wire (55Ft) JL XA-REDPW4- 115 – 4 Gauge Positive Power Wire (55Ft) JL XA-MGL1- B – Master Ground Lug Bolt JL XA-FUSE-ANL- 150 – 150 AMP Blade Fuse (8) JL XA-RT- 4 – 4 Gauge Ring Terminals (8 Pairs) (2) JL XA-BLUSCS12- 130 – 12 Gauge Parallel Conductor Speaker Wire Kits (50Ft) JL XA-BLUAIC4-18 – 4-Channel Audio Interconnects (Sony H.U. to JL 300/4) JL XA-BLUAIC2-18 – 2-Channel Audio Interconnects (Sony H.U. to JL 500/1) JL XA-BLUAIC2-12 – 2-Channel Audio Interconnects (Sony H.U. to Aux Changer) JL XA-BLUAIC2- 9 – 2-Channel Audio Interconnects (10 Disc MP3 to Aux Changer) JL XA-BLUAIC2- 6 – 2-Channel Audio Interconnects (CleanSweep to Aux Changer) Monster Audio MPC S402 2C-15M – 402 XLN Extreme Speaker wire (50Ft) Monster Audio 4 Gauge Terminal Breaker Switch Phoenix Gold Powered/ Fused Distribution Block w/ LED/ Remote LED Status Indicator Voodoo FBVP11DNL – Digital Voltage Meter/Fuse Block Sound-Deadening: Application: 100% Coverage (no bare metal showing) Areas of: Trunk, Trunk Lid, Rear Deck, Rear Seat Deck, Rear Floor, Rear A-Pillars, Under Front Seats, Center Console Area, Front Floor, and Four Doors (Inner Frames & Body Panels) Sound-Deadening Materials: (2) Dynamat Extreme Bulk Packs – 72 total sq/ft Material (1.7mm thick) ~ 33 Lbs (2) B-Quiet Extreme 50ft Rolls – 100 total sq/ft Material (1.15mm thick) ~ 33 Lbs Interior: Auto-dimming Mirror With Compass (only factory option) Rear Center Seatbelt Removal AVO Single Din Cubby Replacement STi Side Sills Kit Authentic STi Floor Mats (2004 Impreza STi) Red Line Goods Shifter Boot (shortened 4” Black Leather w /JDM Quadruple Stitching) Red Line Goods E-Brake Boot (Black Perforated Leather w/ JDM Quadruple Stitching) Red Line Goods Armrest Cover (Black Perforated Leather w/ JDM Quadruple Stitching) STi Carbon Fiber Shift Pattern 2002-2003 Genuine STi Foglight Mesh-Grille custom install into rear deck lid Cup Holder Blue LED Illumination Mod Garmin Nuvi 660 Buried 12V Mod (cell phone charger and Garmin Nuvi charger) Driver Interface: MOMO Steering Wheel (stock) w/ STi Emblem MOMO Aluminum Air Shift Knob / STi Ti Shift Knob / STi Black Delrin Shift Knob STi Metal Pedal Set – Silver/Pink Gauges: Defi BF Boost Gauge Meter – Brass T-Fitting Defi BF Fuel Pressure Gauge Meter – Custom Brass Fuel Pressure Line Adapter Defi BF Oil Pressure Gauge Meter – Subaru Oil Gallery Plug Adapter (3) Defi 60mm Meter Cups (3) Defi Free-Angle Mounts (3) Defi Meter Cup Hoods Custom 3-Meter Cup Bracket Defi Control Link Unit II Custom Control Unit “Hack” Into Ashtray- Frigg’n Sweet!!! Exterior: Debadged Trunk STi Badges RBS Replica JDM Grille RBS Replica JDM Front Lip Spoiler Subaru Moonroof Air Deflector Thule Roof Rack Thule Fairing REI Exclusive Thule Roof Box – Carbon Fiber Pattern (2) STi License Plate Frames – Polished Stainless Protection: Rock Blockers Headlight Protection – Clear Rock Blockers Fog light Protection – Yellow RalliTek Hydro-Cut Aluminum Skidplate – Painted Blue Rally Armor Mud Flaps Security: CompuStar 2WSS Remote Start/ Alarm/ Turbo-timer Safety: Xenon Factory 5000K HID Conversion Kit – PnP Wheels/Tires: Summer Prodrive PFF7 Bright Fitter Alloy Rims (18 x 8, 5x100, ET51 CB, 21.35 lbs) Toyo Proxes T1R Ultra-High Performance Summer Tires 235/40/18 Winter Prodrive P1 Bright Silver Alloy Rims (17 x 7, 5x100, ET52 CB, 20.04 lbs) Nokian WR G2 Performance All-Season Snow Tires 225/40/17 Utility/Off-road Prodrive P7 Gunmetal Alloy Rims (17 x 7, 5x100, ET52 CB, 22.50 lbs) Bridgestone RE092 All-Season Tires 215/45/17 (stock tires) STi JDM Lug Nut Set by McGard – Black Other Modifications: Green Screaming Trunk Monkey w/ Dark Hangover Shades (+10WHP) Here are my mods Link to comment Share on other sites More sharing options...
sportwagon Posted November 19, 2008 Share Posted November 19, 2008 Other Modifications: Green Screaming Trunk Monkey w/ Dark Hangover Shades (+10WHP) Here are my mods Oh sh*t my trunk monkey isn't in the car now... that's a problem -10 WHP Link to comment Share on other sites More sharing options...
katalyst Posted November 19, 2008 Share Posted November 19, 2008 ^ damn i didn't know you had so many mods. i see your car a bunch in sobo where i work, i was gonna park behind you once haha but then it was further of a walk so i didn't. i hate the street cleaning on mondays!! i got a ticket even though i parked on the CORRECT side once, ridiculous! but gonna be transferring out of there soon, maybe i can check your car out at a meet one of these days. Link to comment Share on other sites More sharing options...
HansGT Posted November 19, 2008 Share Posted November 19, 2008 Nice list of mods, although not sure what most of them have to do with your clutch. Anyway as for which "stage" ACT clutch take a look at post #4. Great set up for a stage 2 LGT. Link to comment Share on other sites More sharing options...
sportwagon Posted November 19, 2008 Share Posted November 19, 2008 ^ damn i didn't know you had so many mods. i see your car a bunch in sobo where i work, i was gonna park behind you once haha but then it was further of a walk so i didn't. i hate the street cleaning on mondays!! i got a ticket even though i parked on the CORRECT side once, ridiculous! but gonna be transferring out of there soon, maybe i can check your car out at a meet one of these days. Yeah... I don't even want to begin talking about street cleaning... my car has been towed twice now! I just this month got my registration changed to Southie... but I still have no sticker and I get tickets all the time... it sucks! I think I drove by your car today... on E street... silver 2.5 NA with stock spoiler??? I have been crazy busy as of late... just got married in October, moved from the North Shore to Southie (even though I pretty much lived there now for a while) moving jobs in my company and so on... I'm finally now having time to think about winterizing the Leggy! I'm still rolling on my summers because I haven't had a chance to change over to winter set! I work from 2-10:30pm, so if you want to meet up some time on your lunch break... if you can... just let me know! Link to comment Share on other sites More sharing options...
sportwagon Posted November 19, 2008 Share Posted November 19, 2008 Nice list of mods, although not sure what most of them have to do with your clutch. Anyway as for which "stage" ACT clutch take a look at post #4. Great set up for a stage 2 LGT. Ha ha... Good point! I just have a word document of my mods list... I guess I could have gotten by with just listing the power mods... but I'm sure there are some people that might be able get a better depiction of my clutch needs from looking at my entire car mods list... besides... I have a relatively stock powertrain... but my car is far from stock, wouldn't you agree? Link to comment Share on other sites More sharing options...
sportwagon Posted November 19, 2008 Share Posted November 19, 2008 BTW... SubaruAA - sorry for the threadjack! Have you figured out what you are going to do and where your getting the work done! I for one know where I am going to get the job done- Fastrack Automotive in Peabody! They do great work and have plenty of experience with clutch work on the current generation legacy! Link to comment Share on other sites More sharing options...
HansGT Posted November 19, 2008 Share Posted November 19, 2008 Ha ha... Good point! I just have a word document of my mods list... I guess I could have gotten by with just listing the power mods... but I'm sure there are some people that might be able get a better depiction of my clutch needs from looking at my entire car mods list... besides... I have a relatively stock powertrain... but my car is far from stock, wouldn't you agree? Yep, you have a nice collection of goodies. Link to comment Share on other sites More sharing options...
katalyst Posted November 20, 2008 Share Posted November 20, 2008 Yeah... I don't even want to begin talking about street cleaning... my car has been towed twice now! I just this month got my registration changed to Southie... but I still have no sticker and I get tickets all the time... it sucks! I think I drove by your car today... on E street... silver 2.5 NA with stock spoiler??? I have been crazy busy as of late... just got married in October, moved from the North Shore to Southie (even though I pretty much lived there now for a while) moving jobs in my company and so on... I'm finally now having time to think about winterizing the Leggy! I'm still rolling on my summers because I haven't had a chance to change over to winter set! I work from 2-10:30pm, so if you want to meet up some time on your lunch break... if you can... just let me know! ouch, sucks man.... but congrats on the wedding. yeah the silver 2.5i is me. i'm pretty swamped at work and i've been playing catch up on paperwork over my lunch breaks lately plus i'm transfering next week so i prob won't get the chance to meet up. but i'm sure we'll run into each other later on. +1 for fastrack in peabody, MA /threadjack Link to comment Share on other sites More sharing options...
SubieAA Posted January 30, 2009 Author Share Posted January 30, 2009 No problem. Finally getting back on this. Life was swamped; still is :-). I am going to order the parts, thanks Han'sGT. I work in Framingham which is why I was looking at Speen Street Automotive. Any recommendations on them? I will call Peabody to see if they can do a loaner. No problem on the threadjack. I live in East Boston and parking is always great fun... Link to comment Share on other sites More sharing options...
sportwagon Posted January 30, 2009 Share Posted January 30, 2009 No problem. Finally getting back on this. Life was swamped; still is :-). I am going to order the parts, thanks Han'sGT. I work in Framingham which is why I was looking at Speen Street Automotive. Any recommendations on them? I will call Peabody to see if they can do a loaner. No problem on the threadjack. I live in East Boston and parking is always great fun... Ohhhh... OK... My car is in the shop now getting the clutch installed... along with TXS uppipe, Invidia DP, and perrin mid/y-pipe!!! Link to comment Share on other sites More sharing options...
HiRoller Posted February 4, 2009 Share Posted February 4, 2009 SubieAA: Speen Street is a great shop and they have done a ton of work for me over the years. They do provide loaners. I would check out dentsport garage in Norwood. They have much more experience with an aftermarket clutches than Speen Street and there is a good chance they will be cheaper on the labor. According to their website, a subaru clutch job is priced at $500. They will not have a loaner for you though. Glad to see you're still enjoying the AP. Hiroller Link to comment Share on other sites More sharing options...
SubieAA Posted February 6, 2009 Author Share Posted February 6, 2009 SubieAA: Speen Street is a great shop and they have done a ton of work for me over the years. They do provide loaners. I would check out dentsport garage in Norwood. They have much more experience with an aftermarket clutches than Speen Street and there is a good chance they will be cheaper on the labor. According to their website, a subaru clutch job is priced at $500. They will not have a loaner for you though. Glad to see you're still enjoying the AP. Hiroller Hi Hiroller, Enjoying the AP big time even though I have needed a new clutch for awhile. I will probably upgrading my brakes as well, and may still look at one more suspension upgrade before I go to stage 2. I am a guy that enjoys the 'looks like a family wagon, runs like a porsche' of this car. Stage 2 will probably the ultimate destination, but I am impressed by what some have done. Actually about to by the Iphone outlet cable the guy on this site advertized. Thanks for the heads up about Norwood; I definitely want to make sure it is done very well. Thanks. Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2009 Share Posted February 10, 2009 Definitely go to Dentsport in Norwood over Fastrack in Peabody. Great guys and true performance shop catering to enthusiasts over a wanna-be one. Link to comment Share on other sites More sharing options...
SubieAA Posted February 15, 2009 Author Share Posted February 15, 2009 Definitely go to Dentsport in Norwood over Fastrack in Peabody. Great guys and true performance shop catering to enthusiasts over a wanna-be one. Thanks for the heads up; will checkthem out. Link to comment Share on other sites More sharing options...
SubieAA Posted March 19, 2009 Author Share Posted March 19, 2009 Ordered it today from ACT - $879.33 all in - not too cheap. I am going to go to Dentsport as well. Thanks all. Link to comment Share on other sites More sharing options...
SubieAA Posted April 3, 2009 Author Share Posted April 3, 2009 Well, $2,200 for new clutch, flywheel, 60K service, I can think about stage 2. I could have saved ~400 on parts if I had bought better. Next time and thanks for the advise. The DSG guys were cool. Link to comment Share on other sites More sharing options...
