LGTfoLIFE Posted November 5, 2008 Share Posted November 5, 2008 When I am idling and try to turn my wheel the steering wheel shakes and jerks back and forth I hear a squicking noise outside the car while im trying to turn my wheel I would have to use two hands to turn it and it feels like the power steering dont work. This only happens when my car is not moving. When I drive the car it runs fine no shaking or noise and it turns smoothly. Has anyone had this problem or know what this is? any help or suggestion would be great. Link to comment Share on other sites More sharing options...
outahere Posted November 5, 2008 Share Posted November 5, 2008 Check the belt for proper tension Link to comment Share on other sites More sharing options...
LGTfoLIFE Posted November 5, 2008 Author Share Posted November 5, 2008 The belt could have something to do with the steering? What I also notice when I was leaving the house this morning when I turned my wheel the battery light turned on and when I stop turning it turned back off any reason for that? ohh I got 104,000+miles if that helps. Link to comment Share on other sites More sharing options...
Bdubs Posted November 5, 2008 Share Posted November 5, 2008 If the belt has never been replaced, then it is probably time for a new one. The power steering pump and alternator run off the same belt, so if it isn't tensioned correctly, it is slipping or has too much play, and causing your problems. Link to comment Share on other sites More sharing options...
LGTfoLIFE Posted November 12, 2008 Author Share Posted November 12, 2008 took my car to the dealer yesterday and they said it was the belts. Got them replace and got a 90k service nomore squiking noise and now my car is running smooth! Link to comment Share on other sites More sharing options...
