ProV1 Posted November 4, 2008 Share Posted November 4, 2008 my 09 legacy SE came with 17inch wheels and 205 width tires i think. what is the smallest size tire that will work on this car? will 15inch or 16inch work? what sizes? thanks! Link to comment Share on other sites More sharing options...
ilh Posted November 4, 2008 Share Posted November 4, 2008 In 2005, the base Legacy had 16-inch wheels with 205/55R16 tires. I would guess that would work on a 2009 SE since I don't believe its brakes are as large as GT brakes (which generally require 17-inch wheels). Link to comment Share on other sites More sharing options...
BrownBoy Posted November 4, 2008 Share Posted November 4, 2008 In 2005, the base Legacy had 16-inch wheels with 205/55R16 tires. I would guess that would work on a 2009 SE since I don't believe its brakes are as large as GT brakes (which generally require 17-inch wheels). The front brakes were in fact upsized in 06. Not as big as the GT, but they did require the 17" wheels. There are some 16" wheels that will work, but I do not know which ones. Link to comment Share on other sites More sharing options...
ilh Posted November 4, 2008 Share Posted November 4, 2008 2009 Service Manual lists the following as having "16-inch" type brakes: 2.5i, -BASE, -LTD, 3.0R, Outback 2.5i, -BASE, -LTD, -LLB, Outback 3.0R-LTD, Outback 2.5XT-LTD. Only the 2.5GT-LTD, 3.0R-LTD, and 2.5GT-B are listed as having "17-inch" type brakes. The "16-inch" rotors are listed as 24x294mm as opposed to the "17-inch" rotors 30x316mm. It lists 16x6.5 wheels available for the Canadian 2.5i models, whereas the US models get the 17x7 wheels, yet the brake dimensions appear the same. I think the 2009 SE can take 16-inch wheels, but it would be worth checking with Subaru. TireRack lists 16-inch wheels for the 2009 2.5i SE. Link to comment Share on other sites More sharing options...
