bushbelay Posted October 21, 2008 Share Posted October 21, 2008 1996 Legacy wagon, 5 spd, 98,000 miles. If the car is cold, there is a knock while accelerating in first and second gear. The knock is absent in the other gears and/or if the car has been run for 30 minutes. The noise seems to be coming from the passenger side around the half shafts/transmission area. Boots are not torn and half shafts look solid. The knock does sound similar to a worn half shaft. It does not sound like it is coming from the engine. Any ideas? Thanks in advance. Link to comment Share on other sites More sharing options...
jonklein611 Posted October 21, 2008 Share Posted October 21, 2008 brake shield rubbing on the rotor? Link to comment Share on other sites More sharing options...
bushbelay Posted October 21, 2008 Author Share Posted October 21, 2008 That is a spot I could look. But why is it occurring with the lower speeds/ lower gears? The noise is a deep, throaty noise. I wonder (and worry) could it be something with my clutch? Link to comment Share on other sites More sharing options...
jonklein611 Posted October 22, 2008 Share Posted October 22, 2008 I have zero experience with the MT's, as mine is an AT. could be, maybe a wheel bearing? If it's only when accelerating, could be the trans / motor mounts are worn / loose, or something like that. I know mine clunks when pulling away a certain way, but I've ID'ed that as the tranny smacking the limits of it's mount. Link to comment Share on other sites More sharing options...
Reuben Posted October 22, 2008 Share Posted October 22, 2008 pop the bonnet, and try find it. Is it there when you rev? or only when you're driving? Or even only while turning? is it a knock, tap, rattle or clunk? Link to comment Share on other sites More sharing options...
bushbelay Posted October 23, 2008 Author Share Posted October 23, 2008 The noise is only when I am driving. It occurs if I am going straight or turning. It is a knock. It only occurs when accelerating in first and second gear. Link to comment Share on other sites More sharing options...
Reuben Posted October 23, 2008 Share Posted October 23, 2008 Gearbox, center or rear diffs then maybe? Link to comment Share on other sites More sharing options...
