ZEDD06 Posted October 20, 2008 Share Posted October 20, 2008 What should I be on the "look for" related to repairs/upkeep on my car ('99 2.2 legacy) after 175,000 mile. I just had timing belt replaced, tensioner check, water pump checked, radiator replaced et al. Do I need to wait on something to break or should I replace oil pumps, fuel pumps or other items before a problem. What about differential fluids. I expect to get at least another 100K out of car. The miles are ~80% highway. Thanks for any advice. Link to comment Share on other sites More sharing options...
c-lo Posted October 21, 2008 Share Posted October 21, 2008 really? I hope you aren't really asking if you should wait for something to break before you replace it.! good way to get yourself out of a car. search around, this question came up somewhere. you should still be following a maintenance schedule. I just don't know what it is. http://legacygt.com/forums/search.php? Do I need to wait on something to break or should I replace oil pumps, fuel pumps or other items before a problem. What about differential fluids. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Bdubs Posted October 21, 2008 Share Posted October 21, 2008 Well obviously you aren't going to replace an oil pump (other than when it lets go) unless you are breaking into the engine to replace seals, or something else in the area. If you replaced the timing belt, then would've been a good time to do that, because 1) its cheaper and less of a headache to do it all at once, and 2) you know that when it was replaced, so you shouldn't have to worry about a part like that giving out on you. Keep your eye out on wear items, such as axle shaft boots, any type of oil leak, check all your hoses and connections. If you are unsure about when the diff. fluids were changed, I suggest changing them, because it is possible it has been quite a while. It is suggested to only inspect the Diff. fluid every 30k miles, unless you drive the car under extreme conditions, then you would replace it. Link to comment Share on other sites More sharing options...
McCarthy69 Posted October 21, 2008 Share Posted October 21, 2008 Keep an eye out for the head gaskets if they havnt been replaced. Link to comment Share on other sites More sharing options...
ZEDD06 Posted October 21, 2008 Author Share Posted October 21, 2008 really? I hope you aren't really asking if you should wait for something to break before you replace it.! good way to get yourself out of a car. search around, this question came up somewhere. you should still be following a maintenance schedule. I just don't know what it is. http://legacygt.com/forums/search.php? My book does not provide guidance at 170K mile. I got a note from dealer saying my 168K maintenance is due. Link to comment Share on other sites More sharing options...
bushbelay Posted October 22, 2008 Share Posted October 22, 2008 Keep an eye out for the head gaskets if they havnt been replaced. Are head gaskets really a routine maintenance kind of thing though? Especially on the 2.2. I am surprised to have read that comment for a maintenance question. . . . any thoughts? Link to comment Share on other sites More sharing options...
c-lo Posted October 22, 2008 Share Posted October 22, 2008 ask them for a detailed list of what your maintenance schedule you should follow from here on out. My book does not provide guidance at 170K mile. I got a note from dealer saying my 168K maintenance is due. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
legacy2 Posted October 23, 2008 Share Posted October 23, 2008 2.2s are not known for head gasket issues. at this point the early 2.5s are known for them. Link to comment Share on other sites More sharing options...
