Deunan Posted October 18, 2008 Share Posted October 18, 2008 Anyone know if there is a spring that will fit 2008 Outback XT???? Thanks Link to comment Share on other sites More sharing options...
c-lo Posted October 18, 2008 Share Posted October 18, 2008 use the http://legacygt.com/forums/search.php? function and you'll find what you want. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Deunan Posted November 16, 2008 Author Share Posted November 16, 2008 I did search and couldn't find a single one that fits 2008 Outback XT, it's all for LGT's and it's not compatible with outbacks. any spirngs or coilovers out there for 2008 outback??? Thanks Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 17, 2008 Share Posted November 17, 2008 If you searched on coilovers and outback I know you would find some threads. Anyway though I am running the megan racing coilovers for the outback. Its the only ones available at the time. I really like them alot. I did have some clunking problems from the front but replaced the front shock cartridge in them and they are fine again. Look around on the site for outback coilovers, you could even use my username in the search criteria and you will find them. The only other option is if you look in the ouback forum section I think some were looking into blistein JDM stuff but it was very expensive. Hope that helps! Link to comment Share on other sites More sharing options...
GTBGUY Posted November 19, 2008 Share Posted November 19, 2008 Deunan - here's a thread you should check out -> http://www.legacygt.com/forums/showthread.php?t=75207 Link to comment Share on other sites More sharing options...
