QLQ Posted October 17, 2008 Share Posted October 17, 2008 Is anyone using the Invidia Legacy GT Catless & Catted Downpipes? which version is smooth and maximized exhaust flow? Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted October 17, 2008 Share Posted October 17, 2008 I have the Catless version. I love it. If you are looking for maxium flow, then the catless is the way to go. If want an exhuast that is not as loud, won't smell up the cabin with DP smell and will be better for the environment, the Catted version is for you. Catted version is more expensive though. Link to comment Share on other sites More sharing options...
QLQ Posted October 17, 2008 Author Share Posted October 17, 2008 I see~~ i also prefer the Cateless version... and i just feel maybe is too loud! and your Catless version DP is divorced or bellmouth? what s different between divorced and bellmouth? Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted October 17, 2008 Share Posted October 17, 2008 Mine is divorced. From what understand, the divorced wastegate will keep the wastegate gases from mixing with exhaust gases which may cause turbulence in the DP and decrease flow. People have mixed opinions on whether or not there is a valid performance advantage from the divorced WG. Link to comment Share on other sites More sharing options...
QLQ Posted October 17, 2008 Author Share Posted October 17, 2008 Nice~~~~~ Does Check Engine Light will blink if run this DP? because i saw a Warning on the web which a dealer selling the Invidia DP.. Link to comment Share on other sites More sharing options...
holyjoetart Posted October 18, 2008 Share Posted October 18, 2008 The catless version is pretty stinking loud. It threw a CEL as soon as I fired my car up. Now its off to the dealer to get my turbo replaced. Check your turbo play when you take off the Dp. Its easy!!!! Link to comment Share on other sites More sharing options...
nm Posted October 18, 2008 Share Posted October 18, 2008 Not to be the treehugger of the group, but the minimal power gains and increased cost as compared to the drastic emissions reductions acheived by a cat makes it irresponsible to run catless. The catylitic converter is basically the best thing to happen to our air since trees. Also, it's extremely illegal at the federal level in the US and probably in Canada too. Link to comment Share on other sites More sharing options...
goneskiian Posted October 18, 2008 Share Posted October 18, 2008 Not to be the treehugger of the group, but the minimal power gains and increased cost as compared to the drastic emissions reductions acheived by a cat makes it irresponsible to run catless. The catylitic converter is basically the best thing to happen to our air since trees. Also, it's extremely illegal at the federal level in the US and probably in Canada too. Link to comment Share on other sites More sharing options...
holyjoetart Posted October 18, 2008 Share Posted October 18, 2008 It would be illegal in most states. Wyoming on the other hand is not most states. No emissions laws here. It is better for the environment for me to run cats in my exhaust, but how many high-flow "cats" can pass a California smog test? Link to comment Share on other sites More sharing options...
nm Posted October 19, 2008 Share Posted October 19, 2008 It would be illegal in most states. Wyoming on the other hand is not most states. No emissions laws here. It is better for the environment for me to run cats in my exhaust, but how many high-flow "cats" can pass a California smog test? Uhm, removing cats is illegal under federal law. that means, if Wyoming is still part of the US, it is illegal to run without a cat. Define "pass" High-flows will nearly always pass the sniffer test. And even one that doesn't is still polluting less than an open pipe. Link to comment Share on other sites More sharing options...
affinity1 Posted October 19, 2008 Share Posted October 19, 2008 I have the Catless version. I love it. If you are looking for maxium flow, then the catless is the way to go. If want an exhuast that is not as loud, won't smell up the cabin with DP smell and will be better for the environment, the Catted version is for you. Catted version is more expensive though. If your cabin smells like exhaust I think you may have bigger problems than just being catless. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted October 19, 2008 Share Posted October 19, 2008 ^^ No, you're wrong. Catless DPs are notoriously stinky. Link to comment Share on other sites More sharing options...
j255c Posted October 19, 2008 Share Posted October 19, 2008 Not to be the treehugger of the group, but the minimal power gains and increased cost as compared to the drastic emissions reductions acheived by a cat makes it irresponsible to run catless. The catylitic converter is basically the best thing to happen to our air since trees. Also, it's extremely illegal at the federal level in the US and probably in Canada too. you bought the wrong car, you may want to re-consider and purchase a prius....give me a break, tell that to everyone who has a motorcycle or a classic car. You're not doing much harm to our environment running a catless car. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
SBT Posted October 19, 2008 Share Posted October 19, 2008 I see~~ i also prefer the Cateless version... and i just feel maybe is too loud! and your Catless version DP is divorced or bellmouth? what s different between divorced and bellmouth? Our stock DPs have a small opening for the turbo outlet with a "plate blank" which blocks the turbo's waste gate gas flow and forces it over into the turbo exhaust stream. Invidia DPs have a bellmouth with a curved separator in the bellmouth shaped in such a way as to create a divorced waste gate (DWG) down into the pipe. Invidia uses the bellmouth, with WG separator, on both the high flow catted and non-catted versions. Some DPs, like the Perrin versions, actually have a separate pipe that runs adjacent to the turbo exhaust pipe which feeds the WG gases back into the DP, further along in the pipe. There are different schools of thought on whether a DWG offers any performance gains. I think the larger concensus is that you won't see significant improvement (read: power gains) from a DWG, until you go to a much larger turbo, where you're holding higher boost pressures further into the RPM range and you don't want to create turbulent air flow at the turbo exhaust port and potentially slow down the turbo. Some just knock the catalytic material out of the stock cat and use that. Others use a bellmouth DP w/no DWG (COBB makes this) and both seem to work just fine at elevated power levels on stock and larger turbos. As always, YMMV. Personally, my vote is for the HFC version of whatever brand you're choosing for ecological reasons and just as importantly, to reduce the incidence of boost spike which is dangerous and harmful to your engine - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
nm Posted October 20, 2008 Share Posted October 20, 2008 you bought the wrong car, you may want to re-consider and purchase a prius....give me a break, tell that to everyone who has a motorcycle or a classic car. You're not doing much harm to our environment running a catless car. Get over yourself. Cats are a massive improvement. Removal of HC by almost 300%, CO by over 200%, and NOx by over 350%. And this is versus a dead cat, catless would be slightly worse. The only reason you can still breathe in Los Angeles is the cat. Classic cars generally don't get many miles and are of decreasing numbers. Motorcycles are small motors with minimal emissions (however, they are significantly greater than the should be). I'd bet the annual emissions of these groups are less than a week of modern cars before cats. And then there's the fact that you're removing an emissions device where you'd have these people add them. It costs you nothing to keep your function cat. You want something high-flow for perfromance, but you don't "need" it. What does this have to do with my car choice? I'm not out for the greenest thing possible. With a cat the difference of emissions of these substances is quite minor anyhow. However, there's a line between restricting performance for minimal emissions gain and just throwing the environment out the window. Getting rid of the cat is throwing the environment out the window. It gives you very minimal gains performance gain at little cost. But the benefit to the environment is huge. These are serious pollutants, much worse than the CO2 we worry about today. I'm all for getting as much as you can out of the car within reason. Put a big-ass turbo on, whatever. But shit, for $100 more you can stick on a catted downpipe and improve the emission fo these extremely harmful substances to a massive extent witha loss of horsepower that's comparable to a dyno's margin of error. No, you yourself, won't hurt anything to a major extent. But, like everything with strong negative externalities, it requires all of us to particpate. Tragedy of the commons and all that. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted October 20, 2008 Share Posted October 20, 2008 ^^^ Get over yourself. Link to comment Share on other sites More sharing options...
goneskiian Posted October 20, 2008 Share Posted October 20, 2008 Get over yourself. Cats are a massive improvement. Removal of HC by almost 300%, CO by over 200%, and NOx by over 350%. And this is versus a dead cat, catless would be slightly worse. The only reason you can still breathe in Los Angeles is the cat. Classic cars generally don't get many miles and are of decreasing numbers. Motorcycles are small motors with minimal emissions (however, they are significantly greater than the should be). I'd bet the annual emissions of these groups are less than a week of modern cars before cats. And then there's the fact that you're removing an emissions device where you'd have these people add them. It costs you nothing to keep your function cat. You want something high-flow for perfromance, but you don't "need" it. What does this have to do with my car choice? I'm not out for the greenest thing possible. With a cat the difference of emissions of these substances is quite minor anyhow. However, there's a line between restricting performance for minimal emissions gain and just throwing the environment out the window. Getting rid of the cat is throwing the environment out the window. It gives you very minimal gains performance gain at little cost. But the benefit to the environment is huge. These are serious pollutants, much worse than the CO2 we worry about today. I'm all for getting as much as you can out of the car within reason. Put a big-ass turbo on, whatever. But shit, for $100 more you can stick on a catted downpipe and improve the emission fo these extremely harmful substances to a massive extent witha loss of horsepower that's comparable to a dyno's margin of error. No, you yourself, won't hurt anything to a major extent. But, like everything with strong negative externalities, it requires all of us to particpate. Tragedy of the commons and all that. Well said. Link to comment Share on other sites More sharing options...
holyjoetart Posted October 20, 2008 Share Posted October 20, 2008 Uhm, removing cats is illegal under federal law. that means, if Wyoming is still part of the US, it is illegal to run without a cat. Define "pass" High-flows will nearly always pass the sniffer test. And even one that doesn't is still polluting less than an open pipe. Then anyone going Stg. 2 with a catted, catless, or gutted DP is in violation of the law. Link to comment Share on other sites More sharing options...
korpsepatrol Posted October 20, 2008 Share Posted October 20, 2008 Invidia catted is the way i went on my 5eat and what i am planning to go with my 5mt now. Very good power and no tapering to 2.5 like a the cobb dp. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
05gtlimited300 Posted October 20, 2008 Share Posted October 20, 2008 love my invidia catted DP. perfect fitment, changed the sound a bit and the smell slightly at WOT Link to comment Share on other sites More sharing options...
nm Posted October 20, 2008 Share Posted October 20, 2008 Then anyone going Stg. 2 with a catted, catless, or gutted DP is in violation of the law. Big difference between removing and replacing. Even if you change the cat location (including removing the upipe), you're simply replacing the catalytic converster system. My understanding of the law is that is still legal. Even if it is illegal, I don't think legality should be the prime mover behind it. It's the drastically reduced emissions. Link to comment Share on other sites More sharing options...
QLQ Posted October 21, 2008 Author Share Posted October 21, 2008 I have the Catless version. I love it. If you are looking for maxium flow, then the catless is the way to go. If want an exhuast that is not as loud, won't smell up the cabin with DP smell and will be better for the environment, the Catted version is for you. Catted version is more expensive though. I already have the same setup! Link to comment Share on other sites More sharing options...
holyjoetart Posted October 21, 2008 Share Posted October 21, 2008 Big difference between removing and replacing. Even if you change the cat location (including removing the upipe), you're simply replacing the catalytic converster system. My understanding of the law is that is still legal. Even if it is illegal, I don't think legality should be the prime mover behind it. It's the drastically reduced emissions. You're not replacing the catalytic converter system, you remove all but one cat by going with a catted Dp. All in all, it is better for the environment to go with a catted DP, I chose not to. My CEL went away too. Gotta remeber to plug the O2 sensor back in;) Link to comment Share on other sites More sharing options...
