blue subie Posted October 7, 2008 Share Posted October 7, 2008 Hey i have a problem with my 2007 legacy 2.5i it has 18000km on it and today randomly the check engine light came on as well as the cruise control started blinking. The cruise did not work but then i turned off let it sit for about 30min and it all went away? anyone else have this problem before? Link to comment Share on other sites More sharing options...
Regal05LGT Posted October 7, 2008 Share Posted October 7, 2008 I'd say run by autozone/advance auto/wherever and get them to read the CEL code for you, shouldn't charge you for it. Then you can check what the problem is on here, there's a whole thread with the CEL codes Link to comment Share on other sites More sharing options...
c-lo Posted October 7, 2008 Share Posted October 7, 2008 plenty of threads on this blue subie. use the search function and you'll find what you are looking for. and go to autozone to see what the code is. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
kenchan Posted October 8, 2008 Share Posted October 8, 2008 on my car i read the code, erased, and restarted it. DTC said something about fuel cap bs. i know it wasn't loose. takes a bit longer to turn over while cranking as if you reset the ecu. Link to comment Share on other sites More sharing options...
blackfang Posted October 8, 2008 Share Posted October 8, 2008 I have seen them cross threaded and some cars with bad caps or after market locking caps throwing a code. If you have a problem, the light will come back on though so you will know then. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
