legacy3R Posted October 7, 2008 Share Posted October 7, 2008 I have noticed while driving that if I hit bumps in the road I can see the beams of light from the headlights bouncing. It seems as if the bulbs are loose but I checked them and they are in there tight. Do you think there is something wrong or is this just how it is. Chris Link to comment Share on other sites More sharing options...
urs1ne Posted October 7, 2008 Share Posted October 7, 2008 My right headlight does this a little bit too. I would assume its the whole housing, maybe some extra zipties? ^ n00bs below this line Link to comment Share on other sites More sharing options...
Levish Posted October 7, 2008 Share Posted October 7, 2008 when mine did that it was because the plastic grommet on the headlight housing popped off or wasn't really tight Link to comment Share on other sites More sharing options...
naimouasta Posted October 8, 2008 Share Posted October 8, 2008 the projector inside may be loose?!? mine was. if you take the cap off the back of the headlight, then grab the rear of the projector bulb and gently pull up and down to see if there is any play. my lights were bouncing like you said and i found out it was my driverside. easily fixed by tightening a screw that holds the projector in, but you have to separate you headlights by baking it which maybe scary and a pain in the butt. Link to comment Share on other sites More sharing options...
