joeyj Posted October 6, 2008 Share Posted October 6, 2008 Posted this in the Cobb forums - no response so here goes: The latest issue of Turbo magazine has a dyno test for bolt-on mods on a STI. The Access Port netted +34 WHP. They also gained +13HP with a cold-air intake, but had to richen the tune a bit, cause it leaned the mixture. Do you guys with aftermarket intakes see similar gains on an LGT? I know Cobb says the stock airbox is fine and you won't get any gains, but now I'm confused. My LGT is stock, except for the Access Port. Thanks Link to comment Share on other sites More sharing options...
CTATV Posted October 6, 2008 Share Posted October 6, 2008 from what i read until you do a good more modification than an AP an intake isnt going to net you any power. A good investment is a new panel filter (I have the AVO its a nice cleanable and oil free unit). Gives a bit more woosh as well... http://rallitek.com/avohiflpafi.html Posted this in the Cobb forums - no response so here goes: The latest issue of Turbo magazine has a dyno test for bolt-on mods on a STI. The Access Port netted +34 WHP. They also gained +13HP with a cold-air intake, but had to richen the tune a bit, cause it leaned the mixture. Do you guys with aftermarket intakes see similar gains on an LGT? I know Cobb says the stock airbox is fine and you won't get any gains, but now I'm confused. My LGT is stock, except for the Access Port. Thanks Link to comment Share on other sites More sharing options...
FASTONE Posted October 6, 2008 Share Posted October 6, 2008 I got perrin drop in, lil louder woosh, but no power difference Link to comment Share on other sites More sharing options...
CTATV Posted October 6, 2008 Share Posted October 6, 2008 I got perrin drop in, lil louder woosh, but no power difference drop-in wont give more power unless you are tuning etc... still dont know its more than a marginal increase but much better investment than an intake unless your doing some bigger mods... I myself have removed the intake silencer but am going to fabricate up a tube with some sort of filter/mesh and run it deep down into the wheel well giving me colder air. between the scoop thing @ the front of the hood and the tube sucking from the silencer hold down in the right wheel well & an AVO filter I should be getting plenty of nice cold air for going stage II and at a minmal cost... Link to comment Share on other sites More sharing options...
Regal05LGT Posted October 6, 2008 Share Posted October 6, 2008 I have the k&n typhoon, all it does it make a nice "blow off" sound..... not much if anything for power gains Link to comment Share on other sites More sharing options...
God help me Posted October 7, 2008 Share Posted October 7, 2008 i had K&N, untuned, and saw turbo lag due to wastegate flutter. Link to comment Share on other sites More sharing options...
Guest Gitster Posted October 7, 2008 Share Posted October 7, 2008 Its worthless to even try to add horsepower unless you have a spec. B. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted October 7, 2008 Share Posted October 7, 2008 Link to comment Share on other sites More sharing options...
CTATV Posted October 7, 2008 Share Posted October 7, 2008 Its worthless to even try to add horsepower unless you have a spec. B. sweet glad i got the shrek:wub: Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted October 7, 2008 Share Posted October 7, 2008 Sweet glad i'm completely stock. Cept for your Hogzaust! Link to comment Share on other sites More sharing options...
CTATV Posted October 7, 2008 Share Posted October 7, 2008 yep, not ashamed either, its ricetastic & i love the ricetastic burble it gives me... Link to comment Share on other sites More sharing options...
Guest Gitster Posted October 7, 2008 Share Posted October 7, 2008 :lol: Link to comment Share on other sites More sharing options...
johnAWD Posted October 7, 2008 Share Posted October 7, 2008 Posted this in the Cobb forums - no response so here goes: The latest issue of Turbo magazine has a dyno test for bolt-on mods on a STI. The Access Port netted +34 WHP. They also gained +13HP with a cold-air intake, but had to richen the tune a bit, cause it leaned the mixture. Do you guys with aftermarket intakes see similar gains on an LGT? I know Cobb says the stock airbox is fine and you won't get any gains, but now I'm confused. My LGT is stock, except for the Access Port. Thanks HP gain? None. The stock airbox is more than sufficient for "stage 2+". And a less restrictive panel filter is recommended. If you are looking for more noise, remove the stock airbox silencer/baffle. Link to comment Share on other sites More sharing options...
fonts Posted October 7, 2008 Share Posted October 7, 2008 hp gain? None. The stock airbox is more than sufficient for "stage 2+". And a less restrictive panel filter is recommended. If you are looking for more noise, remove the stock airbox silencer/baffle. +1 Link to comment Share on other sites More sharing options...
joeyj Posted October 7, 2008 Author Share Posted October 7, 2008 Unless you have the Spec B? What is that? Link to comment Share on other sites More sharing options...
fonts Posted October 7, 2008 Share Posted October 7, 2008 Inside joke. There is some debate on the forum whether or not the SpecB is worth the extra money over the LGT. There has also been other debates over setup, HP, etc. AKA Gister is jealous that he doesn't have a SpecB :lol: Link to comment Share on other sites More sharing options...
Guest Gitster Posted October 7, 2008 Share Posted October 7, 2008 No I'm jealous Im not from Canada Link to comment Share on other sites More sharing options...
dmp Posted October 7, 2008 Share Posted October 7, 2008 There's no Joke....spec.B ownes..... Recent comments about the spec.b, verified in CLINICAL STUDIES!!! I heard the spec.B is SOO fast a driver can drive around the world and rear-end himself in his own car. Outer space exists because its afraid to be that close to the spec.B. The spec.B doesn't pwn the twisties...it KILLS them... In a race between a Lamborghini Murcielago and a Ford GT, the winner would be the spec.B - even if it wasn't there. If by some paradox or rift in the space-time continuum a spec.B could race itself...it'd win. Easily. witth the spec.b on the dyno, the car caused a vortex in the space-time continuum and I met God. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
fonts Posted October 7, 2008 Share Posted October 7, 2008 No I'm jealous Im not from Canada Sorry ... got those 2 mixed up :lol: Link to comment Share on other sites More sharing options...
joeyj Posted October 7, 2008 Author Share Posted October 7, 2008 haha - I get it now. I won't mess with a Spec B!! I hear a bone stock one will beat the Nissan GT-R. Link to comment Share on other sites More sharing options...
fonts Posted October 7, 2008 Share Posted October 7, 2008 haha - I get it now. I won't mess with a Spec B!! I hear a bone stock one will beat the Nissan GT-R. True .... Link to comment Share on other sites More sharing options...
dmp Posted October 7, 2008 Share Posted October 7, 2008 No. It won't beat a GT-R. It'll eat the GT-R's children. Then, drive to the GT-R's dad's house and smack it's old-man around. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
lucas569 Posted October 7, 2008 Share Posted October 7, 2008 they say a man named Vimy is the sole master mechanic at SOA that builds each motor by hand... Link to comment Share on other sites More sharing options...
Guest Gitster Posted October 7, 2008 Share Posted October 7, 2008 Link to comment Share on other sites More sharing options...
fonts Posted October 7, 2008 Share Posted October 7, 2008 they say a man named Vimy is the sole master mechanic at SOA that builds each motor by hand... That is also true .... Link to comment Share on other sites More sharing options...
