jim1969 Posted October 9, 2008 Share Posted October 9, 2008 ^No problem. I'm in Suffolk BTW. Link to comment Share on other sites More sharing options...
Jim_KT Posted October 9, 2008 Share Posted October 9, 2008 will do this weekend. Sweet! I'm about to pull the trigger and purchase the ZeroSports splitter. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted October 9, 2008 Author Share Posted October 9, 2008 ^No problem. I'm in Suffolk BTW. I know i really want to check out your car. Are you going to the gtspec meet the 26th. It going to be huge. Link to comment Share on other sites More sharing options...
jim1969 Posted October 9, 2008 Share Posted October 9, 2008 Sweet! I'm about to pull the trigger and purchase the ZeroSports splitter. It's pricey. I bought mine used locally. Link to comment Share on other sites More sharing options...
jim1969 Posted October 10, 2008 Share Posted October 10, 2008 Can you post pictures right now im running my car without number 9 part installed. Looks like this. http://legacygt.com/forums/showpost.php?p=852641&postcount=202 I'm going to cut more of that back flap off so it stops crushing fins. Link to comment Share on other sites More sharing options...
GTTuner Posted October 10, 2008 Share Posted October 10, 2008 The stock splitter was messing up my intercooler. The stock one is not designed for a larger intercooler like the perrin. I used a Perrin unit for a while, I trimmed the engine cover and the hood scoop seal fit perfectly. Never had a problem with splitter interference. In fact, I had washer nozzles mounted on the splitter and they did not interfere. The IC was COLD everytime I stopped the car. Save your money, trim the cover and put the scoop back together....there is plenty of surface area showing to cool effectively. If it is contacting the IC you may need to rotate the turbo housing a bit. Link to comment Share on other sites More sharing options...
SeeeeeYa Posted October 10, 2008 Share Posted October 10, 2008 I used a Perrin unit for a while, I trimmed the engine cover and the hood scoop seal fit perfectly. Never had a problem with splitter interference. In fact, I had washer nozzles mounted on the splitter and they did not interfere. The IC was COLD everytime I stopped the car. Save your money, trim the cover and put the scoop back together....there is plenty of surface area showing to cool effectively. If it is contacting the IC you may need to rotate the turbo housing a bit. You said directly what I tried to say obliquely . Link to comment Share on other sites More sharing options...
GTTuner Posted October 10, 2008 Share Posted October 10, 2008 You said directly what I tried to say obliquely . No kidding brotha. Read on, I guess only great minds think alike:lol: in one ear, out the other Link to comment Share on other sites More sharing options...
