Kyuubi9t Posted October 4, 2008 Share Posted October 4, 2008 My tire pressure light just went off. the problem is that over the summer i had them inflated with ultra-high purity nitrogen, and they claimed the pressure would remain unchanged for a long time. Im confused now as to how they lost pressure so quickly, but on top of that, i dont feel like any of the tires is even underinflated. I dont know the nearest place that i can get more nitrogen pumped into my tires, and im assuming air wouldnt mix well with it? I guess i would have to deflate them all which is what i am trying to avoid. Link to comment Share on other sites More sharing options...
LGT Dave Posted October 4, 2008 Share Posted October 4, 2008 You'll be fine just topping them off with air. Air is 78% nitrogen anyway. They may have lost some pressure if the weather in your area has gotten cooler since they were originally filled up. Link to comment Share on other sites More sharing options...
Kyuubi9t Posted October 4, 2008 Author Share Posted October 4, 2008 You'll be fine just topping them off with air. Air is 78% nitrogen anyway. They may have lost some pressure if the weather in your area has gotten cooler since they were originally filled up. Hey thanks for the insight LGT Dave, you are absolutely correct. I had the tires filled with the nitrogen mid July or so, and since then i have traveled to the other side of the state where it is getting significantly colder. Ill take your advice and top them off with air. Link to comment Share on other sites More sharing options...
