GTkansan Posted September 29, 2008 Share Posted September 29, 2008 I recently tried out a race pipe (cat delete) for the third cat. Couldnt stand the smell of exhaust. So i am getting rid of it (75 bucks anyone?). Anyway, I also did a shorty DP (DWG) at the same time, and now I think i have an exhaust leak. My question is, how tight did everyone tighten down the spring loaded 3rd cat to exhaust bolts? I tightened them all the way down (couldnt remember) and i think the load is causing the DP to 3rd cat pipe to separate under load. Any thoughts? Should i loosen that spring loaded connection? Link to comment Share on other sites More sharing options...
BigBad Posted September 29, 2008 Share Posted September 29, 2008 13 ft lbs for the OEM spring bolts using the donut style gasket, that's all. Link to comment Share on other sites More sharing options...
