jimmy x Posted September 20, 2008 Share Posted September 20, 2008 Hey fellas, I have a exhaust leak! So I bought a new donut gasket. But my concerns are that I might have tighten the bolts and springs to much to that cause the leak. So how much do I tighten it? Link to comment Share on other sites More sharing options...
rkl303 Posted September 21, 2008 Share Posted September 21, 2008 I wouldn't worry too much if you have a leak where the donut gasket is. I remember my friend using an impact wrench w/ a 90ft/lb bar limiter to tighten that spot no real issues. The only one I would really worry is if you jacked up a header to uppipe to turbo inlet gasket, but if you want to do it over again there should be the torque specs in the vacation pix. Just search for them. Link to comment Share on other sites More sharing options...
BigBad Posted September 21, 2008 Share Posted September 21, 2008 13 ft lbs for OEM spring bolts with donut gasket. Link to comment Share on other sites More sharing options...
jimmy x Posted September 21, 2008 Author Share Posted September 21, 2008 Thanks fellas Link to comment Share on other sites More sharing options...
