ilh Posted September 18, 2008 Share Posted September 18, 2008 Is there a walk-through anywhere on how to remove the bumper cover? Our 08 Outback suffered a minor bumper bender and I need to pop out a collapsed corner in the cover. Thanks! --Lee Link to comment Share on other sites More sharing options...
Spec B Posted September 18, 2008 Share Posted September 18, 2008 This is the closest thing I found to a bumper removal walkthrough.. Post #3 http://www.legacygt.com/forums/showthread.php?t=3737&highlight=bumper I will be pulling mine off this weekend for a FMIC install, I will try to take pics. Link to comment Share on other sites More sharing options...
Mark34 Posted September 18, 2008 Share Posted September 18, 2008 +1 That is the thread I used when I took my front bumper cover off to "blackout" the headlights. I found it made it a little easier to turn the wheels to each side to get the poppits located inside the wheel well splash guards. They can be hard to get too. I know because I wound up breaking them while trying to remove them and had to replace them with bolts. Other than that, I think there are 6-8 poppits underneath that are easily removed. Once they are all out, you should be able to wiggle the bumper off. Installation is the reverse of removal. Link to comment Share on other sites More sharing options...
rtbrjason Posted March 18, 2009 Share Posted March 18, 2009 I'm having some trouble with this on my 08.. I got the popits underneath and in the wheel well, but it looks like there is a screw holding it in place that would be impossible to get to.. Not sure how to proceed.. Link to comment Share on other sites More sharing options...
firepyro515 Posted March 19, 2009 Share Posted March 19, 2009 A screw? interesting, mine were just the 6-8 popits underneath and in the wheel well and that was it. May be different for the spec b, but i couldn't imagine why. The biggest thing that always got me was ( for my own subaru ) when replacing the bumper, i had to always start from the right side of the car and work left (towars the diver) otherwise it would not line up right Link to comment Share on other sites More sharing options...
FireB Posted March 19, 2009 Share Posted March 19, 2009 You would take out the pop it right at the end of the bumper (Closest to the Tire). You also take all the necessary pop it underneath the bumper. The Screw you are seeing is the screw for the railing. That Plastic piece is attached to the fender. And your Bumper skin is held on by the railing. So you don't have to take that screw off to take the bumper off. You will see there are about 4-5 tabs right where the Fender and the Bumper+Headlight Meets. You kinda have to wiggle it a bit to take the bumper off. Have patiences!! If you have a very small flat head screw driver, you might be able to get the tabs off a little easier. But be careful not to scratch your paint. Good Luck Link to comment Share on other sites More sharing options...
SubaruTim Posted January 17, 2011 Share Posted January 17, 2011 Bumping an old thread but i have a question. Is there an easy and effective way of taking off the pop-its? I'm not trying to break any of them. Link to comment Share on other sites More sharing options...
Drift Motion Posted January 17, 2011 Share Posted January 17, 2011 theres those pop-it remover Link to comment Share on other sites More sharing options...
SubaruTim Posted January 18, 2011 Share Posted January 18, 2011 Can i pick one up at any automotive place? Link to comment Share on other sites More sharing options...
Drift Motion Posted January 18, 2011 Share Posted January 18, 2011 should be available at any parts store Link to comment Share on other sites More sharing options...
DriveFastTommy Posted January 20, 2011 Share Posted January 20, 2011 Hey Lee, This happened to me recently (not an '08) - I made the mistake of taking it to a mechanic for quick turnover time - cost me a pretty penny. Thanks for the link @SpecB - wish I would have seen this first! Link to comment Share on other sites More sharing options...
