Aex1 Posted September 18, 2008 Share Posted September 18, 2008 Hi, could you help me? I didn't found any confirmation of the issue. I have 2 principal maps at my APv2, Cobb Stage 2 , married already with my OBXT, and the other one: tuned PDX map, made especially for my configuration. Well, what is the optimal flashing procedure: first remove the Cobb map, unmmarring so the AP from the car and only then marry it again, but with PDX map? Or can I flash directly the second map (PDX) over the first one (Coob)? I personally prefer the first variant, but any other opinions, please? Link to comment Share on other sites More sharing options...
LGT Dave Posted September 18, 2008 Share Posted September 18, 2008 There's no need to unmarry the AP and then re-marry it. You just have to flash the PDX map as a Base Map (not a Realtime Map) and it will completely write over the Cobb map on your car now and it will also reset the ECU at the same time. Link to comment Share on other sites More sharing options...
Aex1 Posted September 18, 2008 Author Share Posted September 18, 2008 Well, I understand this in theory, but how is it possible practically? Cobb map is first and base map. How can I flash PDX map? In realtime or flashing? (There are such possibilities during realtime map flashing, you know.) Besides, each firm insists that there maps should be flashed individually. How can? Link to comment Share on other sites More sharing options...
LGT Dave Posted September 18, 2008 Share Posted September 18, 2008 If you select "Reflash Map" (not Realtime) that will install your new map as a Base Map. When you flash a map as a Base Map, it does exactly the same thing that it would do when you marry the AP to the car: erase the map that is currently there from the ECU memory and then install the new map. There is always a base map in the ECU, whether it's a stock one or the Cobb one you have now so even when you marry the AP to the car it still goes through the same process of erasing the map that's there and installing a new one. Link to comment Share on other sites More sharing options...
Aex1 Posted September 18, 2008 Author Share Posted September 18, 2008 Ok, thank you, LGT Dave. Well, I'll try it. The only thing if it's dangerous to the ECU? Mixing two different maps? At PDX site they don't recommend to use maps from different sorce at the same time. So I'm thinking, what does it mean: "at the same time"? Link to comment Share on other sites More sharing options...
LGT Dave Posted September 18, 2008 Share Posted September 18, 2008 "At the same time" means if you had the Cobb map and then installed the PDX map as a "Realtime" map. In that case you would have the PDX map installed on top of the Cobb map and it could cause problems. If you tell the AP to "Reflash" the PDX map, then the Cobb map will be erased and the PDX map will be installed where the Cobb one used to be. Doing a "Reflash" will make it so only the PDX map is there and nothing else so you won't be mixing any maps that way. Link to comment Share on other sites More sharing options...
Aex1 Posted September 19, 2008 Author Share Posted September 19, 2008 Ok, thank you! So during the instalation of any different map (from the different vendors) I should choose "Reflash" and not "In realtime"? Reflashing is more secure, let's say? Link to comment Share on other sites More sharing options...
fishbone Posted September 23, 2008 Share Posted September 23, 2008 Not secure, just a different type of reflash. Base completely rewrites the ECU. Realtime loads up the map quickly and you lose that map if you, for example, disconnect the battery. The base will stay on, no matter what, as if it came that way from factory. Link to comment Share on other sites More sharing options...
Aex1 Posted September 24, 2008 Author Share Posted September 24, 2008 Not secure, just a different type of reflash. Base completely rewrites the ECU. Realtime loads up the map quickly and you lose that map if you, for example, disconnect the battery. The base will stay on, no matter what, as if it came that way from factory. Thanks to all, i can figure out this already. Link to comment Share on other sites More sharing options...
sleeper8406 Posted September 27, 2008 Share Posted September 27, 2008 subscribe Link to comment Share on other sites More sharing options...
Regal05LGT Posted September 27, 2008 Share Posted September 27, 2008 It is not dangerous to the ecu unless the base and realtime maps are mixed, as long as you reflash the base map (ie pdx) and then load the same realtime map you will have successfully reprogrammed your ecu Link to comment Share on other sites More sharing options...
