2008 STi Performance Gauge Pack - 56k beware
Soda Popinski
Posted
I'm pretty sure most of these kits are the same, however, where I ordered it from required me to submit my VIN so they got the exact one. This leads me to believe there may be more than 2 versons of this kit (one for left hand drive, one for right hand drive).
In a nutshell: this is the STi performance tripple gauge pack that fits in the cubby that the USDM (maybe other models) 2008 Legacy has in place of the Navigation. As far as I know, this will NOT fit with the navigation installed, or removed from a navigation equipped vehicle.
I tried to take pictures of the majority of the various parts. The kit comes with everything right down to the butyl rubber, cable ties and screws. Everything you need to complete the setup from start to finish MINUS the tools.
Note: this kit is made for subaru by Defi.
Here's the pictures of what was in my kit.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/STiPerformanceGaugePack.jpg
Entire Kit
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/STiGaugeCluster.jpg
Gauge cluster
It may be hard to notice, but each gauge face is pointed towards the driver. (Left Hand Drive)
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/STiGaugeClusterandbezel.jpg
Gauge cluster with bezel (I may have the bezel upside down)
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/TemperatureSensor.jpg
Oil Temperature Sensor
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/OilPressureSensor.jpg
Oil Pressure Sensor
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/OilPressureSensorhousingandadapter.jpg
Oil Pressure Sensor housing and threadded adapter.
That center threaded post slides out.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/OilPressureSensorhousing.jpg
underside of the adapter
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/TurboGaugeFacebar.jpg
Closeup of the Turbo gauge (in BAR) which I believe is 7.5psi per .5 bar? Correct me if I'm wrong.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/OilPressureFace.jpg
Oil Pressure gauge face
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/OilTemperatureFace.jpg
Oil Temperature gauge face with STi screened on the front left of the cover.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/TurboSensor.jpg
Turbo sensor.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/TemperatureSensorHarness.jpg
Temperature and Pressure sensor harnesses. Notice: they aren't mechanical, but electric.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/PowerHarness.jpg
Power Harness
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/HarnessKit.jpg
Shot of the various harnesses that come with the kit.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/CableTiesprotectionsheetsealingtape.jpg
Kit comes with everything you need to mount and prep the install.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/3WayJoint.jpg
3-way joint
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/ButylRubberandcountersunkmountingsc.jpg
Butyl Rubber and counter-sunk mouting screws.
http://i167.photobucket.com/albums/u148/cherrybloom203/STi%20performance%20gauge%20pack/RubberTube.jpg
Rubber tube for pressure.
  • Replies 83
  • Created
  • Last Reply
Posted
That install is pretty straight-forward, just take your time. The hardest part is actually fishing the wires through the dash up to where the gauge pack mounts. IIRC mine took 4 - 5 hours start to finish, taking my time.
http://www.thel7.com/Wills/2.5GT/Gauge.JPG
Posted
Awesome. I know people wanna see the sweeps and how they work. I was planning on taking it out for a night cruise to show it off. Too bad I can't have it done for tomorrows meet -n- eat at hooters.
Posted
I would like to get this for my car, wish I never bought genome exhaust. Need to get rid of them. Than I can jump in this bandwagon. Would a dealership carry this item.
  • 1 month later...
  • 1 month later...
Posted
Actually 1 Bar is equal to 14.503 psi if anyone is interested.
Actually... 1 bar = 14.5037738 psi.
-Matt
Posted
Def love mine. Install is def a pain (running the wires through the fire wall sucked) but pretty straight forward. Just give yourself plenty of time.
Posted
could you measure it for me?
I don't own one, I've just seen the photos. But it obviously fits in the OEM cubby above the dash, which looks for all the world like a standard DIN, to me.
  • 4 weeks later...
