REDOBXT Posted February 3, 2005 Share Posted February 3, 2005 anyone else notice a click/clunk when your car reaches about 10 mph? i thought it might be the ABS intializing, but that's just a guess. MT Link to comment Share on other sites More sharing options...
Unilat Posted February 4, 2005 Share Posted February 4, 2005 Does this only occur after you have been backing up (i.e. backing out of a driveway)? Link to comment Share on other sites More sharing options...
Hero Posted February 4, 2005 Share Posted February 4, 2005 Most Japanese cars have this nowadays, my old 2001 Honda Civic was notorious for this. Yes it is just the ABS intializing. The thing is that your ABS won't fully work until your car is at least past the first warm up notch. The click thing is just a part of that process Link to comment Share on other sites More sharing options...
c-lo Posted February 4, 2005 Share Posted February 4, 2005 When at 10mph does it click? when you apply the brakes? I had that problem on my 01 outback. my mechanic couldn't find anything wrong (so he says) I was convinced there was. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
REDOBXT Posted February 4, 2005 Author Share Posted February 4, 2005 It may be only after I back up as 95% of the time I'm starting out, I back out of somewhere, I'll check that out (but why does it matter?). And no, my foot is not on the brake when it clicks -- I can actually feel the click ever so slightly with my feet in the pedal area. Link to comment Share on other sites More sharing options...
hadvw Posted February 4, 2005 Share Posted February 4, 2005 anyone else notice a click/clunk when your car reaches about 10 mph? i thought it might be the ABS intializing, but that's just a guess. MT Interesting.. I always thought it was the locks auto-locking.. HV Link to comment Share on other sites More sharing options...
Jaxx Posted February 4, 2005 Share Posted February 4, 2005 must be the abs it not the pad hitting the caliper i have never seen a pad with so many shims ..the pad is isolated on all sides by spring clips Link to comment Share on other sites More sharing options...
Unilat Posted February 5, 2005 Share Posted February 5, 2005 It may be only after I back up as 95% of the time I'm starting out, I back out of somewhere, I'll check that out (but why does it matter?). And no, my foot is not on the brake when it clicks -- I can actually feel the click ever so slightly with my feet in the pedal area. Sometimes pads will shift slightly when brakes are applied - so they click / clunk when first applying brakes in the opposite direction. Based on your description, this obviously isn't what you are hearing. Link to comment Share on other sites More sharing options...
