dbrunone Posted September 8, 2008 Share Posted September 8, 2008 So I'm changing the fluid soon in my Spec.B 6MT, and I'm looking at picking up some 75w90 at some point. What kind should I go with? -Mobile 1 -Red Line -Royal Purple -Something else totally?? The system capacity is 4.3qt for the trans and 1qt for the diff, so I need 6qt of this stuff. Royal Purple is $16/qt, so that will get expensive quick. Any suggestions?? Also, does most of the tranny fluid come out in the pan on the 6MT, or do I have to flush it? Thanks -David Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2008 Share Posted September 8, 2008 IMO Mobil 1 check out Walmart they may have it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
scooby600 Posted September 8, 2008 Share Posted September 8, 2008 I went with Amsoil just because I use Amsoil in everything that I have. It can get expensive but at least you don't have to do it all the time. Also you may want to get a pump to pump out the oil from the container to the rear diff. I got one at autozone for like $5 or $10 bucks. Link to comment Share on other sites More sharing options...
DiscoWagon Posted September 9, 2008 Share Posted September 9, 2008 Motul Gear 300. Link to comment Share on other sites More sharing options...
