LittleBlueGT Posted September 5, 2008 Share Posted September 5, 2008 How often are you checking it? Also how negative are you experiencing? 3-4 times a week, w/ ST it is super easy, so every time I log. I have gotten up to -12 at 3200-400 rpm and around .85 load IIRC. I usually see a trough of pulled timing in the whole row (from left to right) in the 3200-4000 rpm area, except the highest load cell. I have logged it numerous times, started a thread about it on RR, AFRs are right, timing is right, but it doesn't seem to matter. I wonder if my clutch combo makes noise? It is a little audible at real low speeds. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Infamous1 Posted September 5, 2008 Share Posted September 5, 2008 I wonder if my clutch combo makes noise? It is a little audible at real low speeds. That what it is in my case, rarely does it show up in the FLKC though. I can't feel nor hear it while out cruising, but as I am backing up my driveway and in to my garage I can hear the chatter off the walls. Link to comment Share on other sites More sharing options...
qikslvr Posted September 5, 2008 Share Posted September 5, 2008 Would it be possible to add to the logger the functionality to log which knock control strategy is being employed at any given time (even in the absence of knock)? I have a RR logging profile called "timing" that I used when smoothing out my DA table to 6's. I logged with the values listed below. It's a little slow, but it gives a good picture of what's going on. You could add/remove a couple parameters or change the order to suit your preference, but this layout works for me. You can then use the formula/layout Merchgod showed to compare how it arrived at the Total timing value and build your tuning strategy from there. Timing Parameters I use: Engine Speed Engine Load(Calc) and/or Engine Load(Direct) FBKC FLKC Ign. Adv Multiplier Ign. Base Timing Ign. Timing Adv. Ign. Total Timing KC MRP(corrected) MAF V and/or g/sec WBO2(LC-1) Let's kick this pig! Link to comment Share on other sites More sharing options...
