Metal2You Posted September 1, 2008 Share Posted September 1, 2008 The site that hosted ECU Explorer is down. Anybody know another place to download it or get just the drivers for the USB Tactrix cable? Link to comment Share on other sites More sharing options...
enthusiast Posted September 1, 2008 Share Posted September 1, 2008 The drivers are part of EcuFlash. My mod list Link to comment Share on other sites More sharing options...
Metal2You Posted September 1, 2008 Author Share Posted September 1, 2008 Hmm. I guess something else is wrong then. I downloaded ECU Flash and Windows still doesn't notice the USB device at all when I plug it in with the car running. Link to comment Share on other sites More sharing options...
enthusiast Posted September 1, 2008 Share Posted September 1, 2008 When you installed EcuFlash did you notice the part where it asked to install the tactrix drivers? My mod list Link to comment Share on other sites More sharing options...
z28dreams Posted September 1, 2008 Share Posted September 1, 2008 Also, make sure you select the right COM port. The ECUflash drivers basically emulate a COM port on the USB port. You can look to see if it shows up in device properties. Link to comment Share on other sites More sharing options...
Metal2You Posted September 1, 2008 Author Share Posted September 1, 2008 Yes, ECU Flash installed OpenPort 2.0 drivers. I have an earlier Tactrix cable, 1.2 I think. The drivers may be backwards compatible, I don't know. The download link for ECU Explorer is here http://code.google.com/p/ecuexplorer/downloads/list and Calvin, the author of the software, says this driver should work for me: http://www.ftdichip.com/Drivers/VCP.htm since that is what he developed the software with. I'm beginning to suspect my Tactrix cable is shot because other USB devices work fine in the one USB port I have on my laptop, but Windows doesn't see the Tactrix cable at all and doesn't even attempt to setup drivers for it. No "unknown device" prompt or anything. Link to comment Share on other sites More sharing options...
Metal2You Posted September 1, 2008 Author Share Posted September 1, 2008 Also, make sure you select the right COM port. The ECUflash drivers basically emulate a COM port on the USB port. You can look to see if it shows up in device properties. Yeah, I'm not getting the virtual COM port added to my machine at all because Windows doesn't see the Tactrix cable as new hardware. It doesn't recognize I've hooked up a USB device at all. Link to comment Share on other sites More sharing options...
Metal2You Posted September 1, 2008 Author Share Posted September 1, 2008 A system restore to before I uninstalled ECU Explorer didn't fix the issue either. Its gotta be the Tactrix cable. Hopefully I can get Access Tuner to work for logging and tuning once Cobb sends me the updated dongle. Link to comment Share on other sites More sharing options...
z28dreams Posted September 1, 2008 Share Posted September 1, 2008 Metal - if you want to pay for shipping, I'd be willing to test out your tactrix cable on my laptop and see if it works. (or check out your local legacygt / nasioc chapter) I'm located near DC. Link to comment Share on other sites More sharing options...
