caramall2 Posted August 23, 2008 Share Posted August 23, 2008 Have read several threads, but thought I'd throw this out again...trying to get some good numbers to set my map at. The two factors I know of that may need to be adjusted are: 1) Injector Scale 2) Injector Latency For #1, seems like most have used around 3655 (vs 5200 stock). For #2, some have said leave stock, some have said you will need to increase it slightly (is slightly like 0.1?). Cobb ST info says: "To tune this table, it is suggested that you first establish a good Injector Scaler value through a best guess estimate. Adjust the latency values with the car at idle. If the car is running lean (positive fuel trim correction values) you should try increasing the latency value. Doing so will extend your total injector on-time. If the car is running rich (negative fuel trim correction values), try decreasing your latency values. In most cases, aftermarket injectors are slower than the factory injectors and thus need higher fuel latency values." In Rom Raider, to check on fuel trim correction, is it AF Correction %, AF Learning %, or AF Lean Correction? Thanks. Link to comment Share on other sites More sharing options...
boostsr20 Posted August 23, 2008 Share Posted August 23, 2008 Check AF stored C and D. You want them Within 2% and 5% respectively. The closer to 0 the better. Since DW's are supposedly built off stock injectors some say the latencies shouldn't change but I've seen some people increasing them slightly at 14v by (.1) Link to comment Share on other sites More sharing options...
qikslvr Posted August 26, 2008 Share Posted August 26, 2008 You will just have to tweak latency a little at idle to get the A/F trims right, but that's about it. My latency is 1.32 at 14V for my DW740's. Let's kick this pig! Link to comment Share on other sites More sharing options...
NSFW Posted August 26, 2008 Share Posted August 26, 2008 I used the Learning View tool to read the fuel trims. I think "AF Learning #1 A" (and B,C,D) might be the same values but I haven't verified that. My Perrin 816s needed some extra latency as well, see here for the details: http://www.romraider.com/forum/topic3601.html Link to comment Share on other sites More sharing options...
Ridgeracer Posted August 26, 2008 Share Posted August 26, 2008 I used the Learning View tool to read the fuel trims. I think "AF Learning #1 A" (and B,C,D) might be the same values but I haven't verified that. My Perrin 816s needed some extra latency as well, see here for the details: http://www.romraider.com/forum/topic3601.html Good post on RR NSFW. I need to scale some TDC modded 816 cc inj. too. I believe they are about the same as the Perrin modded (someone correct me if I'm wrong). Anyone scale these inj. w/ an AVO intake? Right now I have 750cc as the scaler but I still run rich at WOT. Fuel A/F trims in Closed loop are are within 2%. Need to confirm the latencies later. At work. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
G.T.Subie Posted September 1, 2008 Share Posted September 1, 2008 Denial is your best friend Link to comment Share on other sites More sharing options...
caramall2 Posted September 1, 2008 Author Share Posted September 1, 2008 It may be a week or two...but I want to get them in before I hit the track in a month. Link to comment Share on other sites More sharing options...
