Golf4283 Posted August 22, 2008 Share Posted August 22, 2008 So I have been looking at the tire sizing guide and it doesn't state whether the rims are 8" wide or 7" so I thought I would make a post to try and get the information I need. I just got two flat tires from a pothole and my new rims are ready to go. I have a set of 18x8" rota Torques and I need to know what size tire I can run where I don't have to worry about the speedo being out of whack. I dont know how tall and Wide I can fit also. Please some insight as my brand new car is out of commission now. Thanks Link to comment Share on other sites More sharing options...
Golf4283 Posted August 22, 2008 Author Share Posted August 22, 2008 Also I'm going with the BFG Gforce KDW's and I think they don't come in 45 tall sizes so would a 235/40/18 give me a good choice on my 3.0R. I really don't want the speedo to get all screwed up. I'm running a stock suspension for now so clearance shouldn't be too bad an issue. Link to comment Share on other sites More sharing options...
bradlgt21 Posted August 22, 2008 Share Posted August 22, 2008 http://www.legacygt.com/forums/showpost.php?p=68297&postcount=1 Copied from the above thread 215mm = 6.5", 7", 7.5" and 8" 225mm = 7", 7.5", and 8" 235mm = 8", 8.5", and 9" 245mm = 8", 8.5", and 9" 18 in. rims (for Spec B.2006-on, 3.0Rs 2008-on): 225/40/18 (common tire to use and gives a better acceleration since it's 0.5" shorter) 235/40/18 (rare size to find, but near stock height for proper gearing) 245/40/18 (popular tire size for the larger cars) So any of the above sizes will fit on your 18x8 As for width look, 225 sits flat with the rim and 245 bubbles out. I have 225's on my LGT on the same rims as you have and like it. Link to comment Share on other sites More sharing options...
Golf4283 Posted August 22, 2008 Author Share Posted August 22, 2008 Yea That's the post I'm talking about. I just want an answer. Not pointing me to something I don't understand. Link to comment Share on other sites More sharing options...
bradlgt21 Posted August 22, 2008 Share Posted August 22, 2008 I edited now so I hope it makes more sense. The first set of numbers is the width of the tire or the first number in the tire size 225/xx/xx. So they are saying with 8 inch wheels you can go anywhere from 215-245. The second set of numbers is his recommendations and overall tire sizes including sidewall and everything. Those 3 are the closest to stock and you will be ok running them. Just understand that when you change from the stock tire size your speedo will not be 100% accurate but unless you change a lot you shouldn't have a problem. Pretty much you have three options of tire sizes 225/40/18, 235/40/18, and 245/40/18. I would suggest the 225 for looks but for your speedo being the most acurate I would go with the 245's. Link to comment Share on other sites More sharing options...
bradlgt21 Posted August 22, 2008 Share Posted August 22, 2008 Here is a good link to find out how different the tire is and how much it will effect your speedo. Just put in what the stock tire size is and then which tire size you are thinking about running. it will tell you how off it will be. http://www.miata.net/garage/tirecalc.html Link to comment Share on other sites More sharing options...
Golf4283 Posted August 22, 2008 Author Share Posted August 22, 2008 Great thanks. I was actually leaning towards the 235's so maybe that's a happy medium. My mustang has 245's and they do bubble out a bit. Link to comment Share on other sites More sharing options...
bradlgt21 Posted August 22, 2008 Share Posted August 22, 2008 Yeah good call. Plus with 245's you might have to worry about them being so wide you would need to roll the fenders. If you are on stock springs you should be fine but lowering would make 245's rub most likely. Link to comment Share on other sites More sharing options...
lawl Posted August 23, 2008 Share Posted August 23, 2008 235/40 rub on my car. it's lowered 225/40 do not. rubbing is bad. car for sale. PM me! Link to comment Share on other sites More sharing options...
Golf4283 Posted August 23, 2008 Author Share Posted August 23, 2008 hmm. So you guys think 225/40s? Link to comment Share on other sites More sharing options...
cfdrumr Posted August 24, 2008 Share Posted August 24, 2008 I just threw Federal 595ss 225/40 on my 18x8 Rotas...no rubbing, look wide...good enough for me. Link to comment Share on other sites More sharing options...
fweasel Posted August 24, 2008 Share Posted August 24, 2008 hmm. So you guys think 225/40s? I put 225's on my 18x8 summer wheels and they have never rubbed. 235's did. I'm lowered on Ions. Regardless, I have never missed the extra tire width vs. the security of never having to worry about my tires being cut. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Golf4283 Posted August 24, 2008 Author Share Posted August 24, 2008 I ordered a set of BFG Gforce T/A KDW's in 225/40/18. What do you guys think? Link to comment Share on other sites More sharing options...
fweasel Posted August 24, 2008 Share Posted August 24, 2008 I ordered a set of BFG Gforce T/A KDW's in 225/40/18. What do you guys think? I think you won't have any problems with them, until they get loud. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
cfdrumr Posted August 24, 2008 Share Posted August 24, 2008 my friend has them on his IS...cool looking and good grip but too loud for my taste...atleast for a DD Link to comment Share on other sites More sharing options...
Golf4283 Posted August 24, 2008 Author Share Posted August 24, 2008 well it looks like sound deadener is next on my list haha. Link to comment Share on other sites More sharing options...
Scooby Fan Posted August 27, 2008 Share Posted August 27, 2008 I'm running 225/40/18 P Zero-Neros on 18X8 OZ Cronos...love 'em:) Link to comment Share on other sites More sharing options...
VXCL Posted August 28, 2008 Share Posted August 28, 2008 my largest wheel / tire setup ***remember that tire size varies by model and brand so 235 from say goodyear may be larger then a 235 from dunlop or whatever. tirerack has all the specs you need to help find the right tire for ya*** JDM Spec B Rev A Bilsteins -Prova Sedan Springs (F: 4.35kg / 25mm drop, R: 6.7kg /20mm drop) -double rear spring pads 18x8 OZ Ultraleggeras -48mm offset -235/40 Goodyear Eagle F1 GS-D3s (1 finger gap all around) http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1841.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1855.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1836.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1857.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1843.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1848.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1846.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1849.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1864.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1863.jpg FRONT FITMENT http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1822.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1823.jpg http://mywebpages.comcast.net/vxcl/legacy/blackOZ/IMG_1826.jpg COMMENTS: -perfect fitment except I had to remove the rubber strip along top of rear fender becuase it rubbed -if the spec b wheels could clear brembos i would have kept them instead, but oh well -if OZ superturismos came in an 18" fitment for the lgt i would have done that, but they are my winter wheels in 17s -ride is great and quiet and the f1s are hella sticky ***this size tire may not fit on oem struts since they have less clearance then bilsteins because the spring perch sits lower*** MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
caramall2 Posted September 5, 2008 Share Posted September 5, 2008 I have the KDW 2 (with the funky tread pattern) and they have held up incredibly well, even after about 20k. I took them to a two-day track event and they were great (and I drove them quite hard). They're solid in the dry, solid in the wet. They've worn very evenly (I've rotated them of course, and set significant front camber at the track (I have coilovers)). Weakness? Very noisy for some, just a little noisy for others (like me). If noise doesn't become an issue for you, I think you'll like them. Link to comment Share on other sites More sharing options...
Golf4283 Posted September 5, 2008 Author Share Posted September 5, 2008 I have them on now and noise hasn't been a problem at all. maybe I'm just a lucky one running them. I'll get some shots up of my car when I can detail it cause these rims are hot. Link to comment Share on other sites More sharing options...
