mschmidt Posted August 13, 2008 Share Posted August 13, 2008 All, I installed a set of used MR coilovers a few months ago (~5K miles) and had some clicking come from the drivers front coilover while backing out of my driveway or turning in a parking lot. Turning the steering wheel slow I would feel it get a little tight... then the "click"... it would do this roughly a half dozen times turning in either direction. It does this if I turn fast or slow. I later found out that I did not torque the top nuts down correctly and ended up chewing up the threads on this coilover only. I ordered a new core and recently rebuilt the coilover. I tightened down the top nut as much as I physically could holding the allen wrench in my vise. Reinstalled it today and I have the same exact clicking sound. It is dropped about 1.5" inches and I eyeball the camber at about -1 degrees. While I was waiting for the new core I put back on the stock struts up front and the clicking was not present. This clearly has something to do with the MR coilover. Any ideas? - Impact gun on the top nut? I can't imagine it is not tight enough? - Buy an entire new coilover and try it? Perhaps something else is broke on the coilover? Let me know? I can take a video of the condition if you feel it will help diagnose the problem... Thanks, Mike Link to comment Share on other sites More sharing options...
mschmidt Posted August 14, 2008 Author Share Posted August 14, 2008 I was thinking about this some more... even though removing the MR coilover got rid of the sound, it may not actually be the culprit? Am I stretching here? What does the coilover do to other components that may cause one of them to make this sound? The only significant difference is the lowering... Could the resultant lowering of the front end affect any other components? Sway bar making this sound perhaps? Let me know guys? Link to comment Share on other sites More sharing options...
mschmidt Posted August 17, 2008 Author Share Posted August 17, 2008 bump Link to comment Share on other sites More sharing options...
kneedragger Posted August 18, 2008 Share Posted August 18, 2008 Try a couple of washers beneath the nut to see if it solves the problem. Could be the nut has reached the limit of the threads so if you try to tighten it more you will only break a pooper valve or even worse, some suspension! Link to comment Share on other sites More sharing options...
mschmidt Posted August 18, 2008 Author Share Posted August 18, 2008 pooper valve? How could I break some suspension? Thanks for the idea. I will take a look and see if I can tell if the nut is all he way down to the bottom of the threads. Hopefully Boostjunkie can chime in. Link to comment Share on other sites More sharing options...
Boostjunkie Posted August 18, 2008 Share Posted August 18, 2008 When you installed the new damper core, did you check for or notice any play in the pillowball? There are only 2 moving parts in the coilovers, the damper and the pillowball. Since you have already replaced the damper, the only other possible source of noise from the coilovers is the pillowball. BTW, there is no need to death torque on the top nut. 35-40ft/lbs is plenty. I'm pretty sure you've got at least that much on there right now, so that's probably not it. Link to comment Share on other sites More sharing options...
mschmidt Posted August 18, 2008 Author Share Posted August 18, 2008 death torque... nice. I don't remember any play in the pillow ball. I can't see how that would result in this clicking if there was a little slop. The clicking is the same sound that if I would go out there now and turn on the top nut without holding onto the shaft. This is odd and very annoying. My wife is scared to ride in my car... well, more scared now. Link to comment Share on other sites More sharing options...
Saul_Good Posted August 18, 2008 Share Posted August 18, 2008 Like Boost said it could be your pillowball. I had this exact problem and the noise was annoying -- like a rattle sound over road imperfections. The way i fixed it and it's still fine to this day is using a 17mm (could be wrong on the size) and an 8mm hex wrench and tightening it that way. I know you did this while it was in your vise but do it again while its installed in the car. Im pretty sure that will solve your problem. I repeat this every so many months just in case, because i track the car. Also, you don't have to 'death torque' it either. Let us know how it turns out. Link to comment Share on other sites More sharing options...
mschmidt Posted August 18, 2008 Author Share Posted August 18, 2008 Does anything look wrong in the pics below? Sitting in neutral with my hand on the top nut and the other turning the steering wheel I can certainly feel the click in the top nut. It sounds like it is jumping on a couple threads perhaps? I took the top nut off and watched the shaft closely as I turned the wheel. I could see it rise up a thread or two and shift the castor a little bit. Thinking I ran out of thread I put two washers on and death torqued it again with no success. Let me know guys. http://img.photobucket.com/albums/v238/mschmidt/DSC05927.jpg http://img.photobucket.com/albums/v238/mschmidt/DSC05931.jpg http://img.photobucket.com/albums/v238/mschmidt/DSC05936.jpg Link to comment Share on other sites More sharing options...
mschmidt Posted August 19, 2008 Author Share Posted August 19, 2008 Do I need a new pillow ball? I'm about to just order a brand new coilover and call it a day. Let me know what to do guys. Mike Link to comment Share on other sites More sharing options...
mschmidt Posted August 20, 2008 Author Share Posted August 20, 2008 bump Link to comment Share on other sites More sharing options...
mschmidt Posted August 25, 2008 Author Share Posted August 25, 2008 bump Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 I am having the same probelm with my BC Coilovers. Clicking.... Link to comment Share on other sites More sharing options...
mschmidt Posted August 25, 2008 Author Share Posted August 25, 2008 huh... Boost were you at Link to comment Share on other sites More sharing options...
mschmidt Posted August 30, 2008 Author Share Posted August 30, 2008 bump for some advice Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 3, 2008 Share Posted September 3, 2008 Was thinking about your problem. Try and tighten the lower lock ring that holds the lower strut mount in place. If this move just a little when you turn or go over bumps...equals alot of noise. Also grease the top and bottom of the springs. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
mschmidt Posted September 3, 2008 Author Share Posted September 3, 2008 Are you talking about the big ring that you use the special tools to tighten? This one is tight. I did spray them down with WD40 as well. This is probably not it. thanks though. Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 3, 2008 Share Posted September 3, 2008 Are you talking about the big ring that you use the special tools to tighten? This one is tight. I did spray them down with WD40 as well. This is probably not it. thanks though. Yeah..I thought mine was tight enough as well but they apparently were not. They have to be very tight...at least with my Ksports... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
mschmidt Posted September 4, 2008 Author Share Posted September 4, 2008 Just checked... mine is very tight. Link to comment Share on other sites More sharing options...
mschmidt Posted September 8, 2008 Author Share Posted September 8, 2008 bump Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted September 8, 2008 Share Posted September 8, 2008 You didn't hear back from Boostjunkie? Link to comment Share on other sites More sharing options...
mschmidt Posted September 8, 2008 Author Share Posted September 8, 2008 Nope, I even sent him some PM's. He must be busy. I just want to order a new coilover and be done with it. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted September 8, 2008 Share Posted September 8, 2008 Do you have caster bushings too? Link to comment Share on other sites More sharing options...
mschmidt Posted September 8, 2008 Author Share Posted September 8, 2008 no, I have no idea what castor bushings are. enlighten me. I assume you recommend I upgrade these? Link to comment Share on other sites More sharing options...
