utgt Posted August 12, 2008 Share Posted August 12, 2008 Will a spec 2+ clutch work with an act street light flywheel? I assume it would but just wondered if anyone knew for sure before I order it. Link to comment Share on other sites More sharing options...
Infamous1 Posted August 12, 2008 Share Posted August 12, 2008 No, the ACT flywheel is 06+ WRX fitment while the Spec clutch is a direct replacement to be used with a LGT flywheel. Link to comment Share on other sites More sharing options...
Mr. Ed Posted August 26, 2008 Share Posted August 26, 2008 well, an 06 spec 2 clutch and an 06 stock flywheel would work... basically spec/spec or speck/stock...don't mix and match. and everything is model specific. what exactly is your goal? the lgt specific spec clutch/flywheel seems to be good. why not do the wrx act clutch and the wrx fly? I did a wrx spec stage 1 clutch and wrx fly. it was great for about 30k at stage2 powers..then it started slipping Link to comment Share on other sites More sharing options...
Malingator Posted August 26, 2008 Share Posted August 26, 2008 You can keep your stock flywheel and run a spec clutch...if it can not be re-surfaced spec makes a direct replacement as well. It's a single mass not a dual (stock) so there will be some clatter especially during break-in. I have a stage 3+..if you are runnning higher HP/TQ numbers you might as well go stage 3+..it has the EXACT same feel as the stage 2 and cost the same..it will hold much more power. Link to comment Share on other sites More sharing options...
