tommboy Posted July 27, 2008 Share Posted July 27, 2008 So I nailed a curb today pretty bad and there is a small sized chunk taken both out of my rim and tire, the tire just seems lim a piece of it was cut because it's still attached. My question is will my tire be ok will I need to get a new one? Will it atleast hold up for a 300 mile drive back home I'm doing today? Link to comment Share on other sites More sharing options...
BENCOB Posted July 27, 2008 Share Posted July 27, 2008 Depends on how much you value your life......If not your life, then the life and property of other folks during your 300 mile trip......Change it out......Peace Link to comment Share on other sites More sharing options...
nm Posted July 27, 2008 Share Posted July 27, 2008 Picture? If the chunk is just the "rim protector," it's designed to do that. If it's pretty much anything else, you need new tires. Plural, as in 4 new tires. Link to comment Share on other sites More sharing options...
rurouni_x Posted July 27, 2008 Share Posted July 27, 2008 If you can see the nylon threads then replace it asap if its just rubber than its just cosmetic. Link to comment Share on other sites More sharing options...
SBT Posted July 28, 2008 Share Posted July 28, 2008 And if you hit it hard enough to scour the rim and take a chunk, an alignment check is likely in order (unless this is a rear wheel - then not so much). But if the "chunk" you refer to is large, exposes cording, or looks like it's cracking further, then definitely replace all four tires. If it's just in the rim protector, I wouldn't worry about it. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
nm Posted July 28, 2008 Share Posted July 28, 2008 And if you hit it hard enough to scour the rim and take a chunk, an alignment check is likely in order (unless this is a rear wheel - then not so much). But if the "chunk" you refer to is large, exposes cording, or looks like it's cracking further, then definitely replace all four tires. If it's just in the rim protector, I wouldn't worry about it. Adding to this, even if the tire looks ok now, monitor it for a developing tire buldge. Link to comment Share on other sites More sharing options...
SBT Posted July 28, 2008 Share Posted July 28, 2008 Adding to this, even if the tire looks ok now, monitor it for a developing tire buldge. Absolutely - and glad you added this. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
tommboy Posted July 29, 2008 Author Share Posted July 29, 2008 I'll keep an eye on it but I'm pretty sure it's just cosmetic taking a second look, is it ok for me to glue the hanging/cut part ? Or is there something better than glue I should use? Link to comment Share on other sites More sharing options...
