ClwLegacyGt08 Posted July 21, 2008 Author Share Posted July 21, 2008 the two codes have been PO420, and P0244. If i am running into this problem due to no cats can i have a shop install a high flow cat in the dp, and shave the divider to help reduce wastegate interference... Link to comment Share on other sites More sharing options...
Christian. Posted July 21, 2008 Share Posted July 21, 2008 the two codes have been PO420, and P0244. If i am running into this problem due to no cats can i have a shop install a high flow cat in the dp, and shave the divider to help reduce wastegate interference...I have PM'ed you. Have you had the downpipe ground down to allow for WG valve clearance? I will continue to work with you until we get these issues resolved. Please e-mail me back with your findings. Take care, Christian. Link to comment Share on other sites More sharing options...
Pdizzleccc Posted March 29, 2009 Share Posted March 29, 2009 I hate bringing up a dead forum, but has anyone else run into this issue, I just picked up the invidia dp, and am seeing issues with a rallitek map, but not cobbs...jasone did you ever get pics of how far your ground it down Link to comment Share on other sites More sharing options...
ClwLegacyGt08 Posted April 4, 2009 Author Share Posted April 4, 2009 umm wastegate is hitting the divorced part, shave it down, and should solve it. Link to comment Share on other sites More sharing options...
