sgtpeper Posted January 26, 2005 Share Posted January 26, 2005 I did some searching and did not find much on this so.... Is it possible to have the wagons biiiig sunroof installed on the sedan? I think this would be quite remarkable if possible Jeff Link to comment Share on other sites More sharing options...
axis008 Posted January 27, 2005 Share Posted January 27, 2005 I don't think you can, since the sunroof will have to retract somewhere. Unless you have it slide up and back, but that will look weird, in my opinion. -ben Link to comment Share on other sites More sharing options...
D-2.5-GT Posted January 27, 2005 Share Posted January 27, 2005 don't forget the structure of the car also. It would have to be beefed up to handle any impact with a huge hole in the roof. Link to comment Share on other sites More sharing options...
sgtpeper Posted January 27, 2005 Author Share Posted January 27, 2005 Doh! Still would be sweet to have a more panaramic sunroof in the LGT Jeff Link to comment Share on other sites More sharing options...
sde Posted January 27, 2005 Share Posted January 27, 2005 oh man, big sunroof and safari windows would be cool Link to comment Share on other sites More sharing options...
jdepew Posted January 27, 2005 Share Posted January 27, 2005 oh man, big sunroof and safari windows would be cool haha - gotta go with a Ranger Rover for those. But I doubt anything short of the new RR Sport or RR Supercharged (two different cars, Sport based on LR3, Supercharged is a true RR) would be nearly as much fun as the Leggy. Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted January 31, 2005 Share Posted January 31, 2005 I would particularly like a glass roof option. Doubt it will happen, though. The existing sedan sunroof slides into the roof, because it is shallow enough to do so. Unfortunately, the wagon's glass roof is so much deeper, it wouldn't retract all the way before hitting the rear glass. Up and over the roof is another option, I suppose, but more susceptible to damage from debris when up like that... Not only that, but the roof of the wagon angles up further at the front, where the sedan is more flat. I wouldn't mind a full glass roof option, with a front and rear glass panel, kind of like a new Mini, Tc, or a Merc C-class small coupe. Something where the front glass moves down and under the rear glass when it opens. The whole roof between the rain rails, from the windsheild to the rear glass could be painted black, to make it look uniform. Again, likely not gonna happen. too bad. though. Link to comment Share on other sites More sharing options...
bemani Posted January 31, 2005 Share Posted January 31, 2005 You can go ask if anyone can do a G6 type sunroof. Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted February 2, 2005 Share Posted February 2, 2005 I just wonder about the "ring structure" of the subaru Unibody. I think there is a major crossmember through the middle of the sedan's roof between the B-pillars. but I could be wrong. It would have to be engineered for the sedan sunroof to pass through or around it... If that is the case, a full glass roof might be a challenge, even a slatted stack-opening version. It would be very cool, though, if it could be done. But then again, the wagon's sunroof is huge, and occupies the area where any such b-pillar cross brace would be, but the wagon's roof structure could have the crossmember between the C-pillars, and still be roughly in the middle of the roof, between the headers above the windsheild, and the tailgate in the rear. It is an interesting premise, though. I did see in a magazine the other day that Classic Design Concepts has developed a "glassback" roof for the 2005 Mustang, where they replace the roof skin sheetmetal with curved, tinted glass from the windsheild to the backlight. That would be pretty cool, even though it probably doesn't open. The mustang hasn't had any sort of glass sunroof/T-top option since the early nineties. I hope the Mini, Tc, G6, etc. prove that the glass roof options are both popular and viable to produce on a large scale. Maybe then more cars will start sporting them. Link to comment Share on other sites More sharing options...
