PeterJMC Posted July 2, 2008 Share Posted July 2, 2008 I'm a n00b when it comes to tuning and any upgrades that go past stage 2. I'm hoping some of you experienced folks can help me out... I have the option of a CAI with stock MAF or one that is 74mm. Question is... which should I choose? Would the car be driveable to the tuner if the 74mm version was selected while running on a stage 2 map? My upgrades that I plan on installing... Cobb Accessport APS headers FP 20g Cobb catted DP Prodrive BCS WBR FMIC TGV delete DW 750 injectors Walbro fuel pump Link to comment Share on other sites More sharing options...
PeterJMC Posted July 2, 2008 Author Share Posted July 2, 2008 From these threads it seems like I would be good with getting the stock size MAF with a WBR FMIC and a 20g rather than the larger 74mm. Anyone else have some input or suggestions? I want to make sure I get the right size MAF for my setup. http://www.legacygt.com/forums/showthread.php?t=75495&highlight=voltage+maf http://www.legacygt.com/forums/showthread.php?t=24810&highlight=voltage+maf http://legacygt.com/forums/showthread.php?t=53097&highlight=maxing+MAF Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 2, 2008 Share Posted July 2, 2008 A 20g maxxed out is gonna get pretty close to maxing out the MAF, at least if it is the size of an AEM CAI. That being said, the stock size MAF housing is 70mm IIRC, and an aftermarket one that is actually 70mm (which is bigger then the AEM I believe) should be OK. It it were me I would get the bigger MAF housing. You know for sure that it will support your power levels. I think the car will start, and then stumble around for a bit until it learns the AFR a bit for the 74mm intake. Then I think it would likely drive OK (moderate to slow driving only) to get to a tuner. I am sure others have more experience though. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 2, 2008 Share Posted July 2, 2008 Oh, and one other thing, I would likely flash the stock map back in vs a generic stage2 map. Little bit bigger margin for safety. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
PeterJMC Posted July 2, 2008 Author Share Posted July 2, 2008 Thanks LBGT. Anyone else have some input? Link to comment Share on other sites More sharing options...
rc0032 Posted July 2, 2008 Share Posted July 2, 2008 No the SOB is right Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 2, 2008 Share Posted July 2, 2008 No the SOB is right You do realize I have learned the odd thing in the past three and a half years, right? You on the other-hand............................ Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
rc0032 Posted July 2, 2008 Share Posted July 2, 2008 I learned about beer I knew about the car Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted July 3, 2008 Share Posted July 3, 2008 You will likely max the MAF with anything equal to or smaller than the AEM with a 20G at greater than 20psi. On cool days I pegged the MAF at 5 volts several times and received a CEL for my troubles. The AVO has given me some much needed headroom - I now max at about 4.78 or 4.80 volts. Link to comment Share on other sites More sharing options...
bugblatterbeast Posted July 3, 2008 Share Posted July 3, 2008 don't forget to factor in winter driving. in Canadian weather, if you are much above 4.8 now, you will be pretty close to saturation come winter. Link to comment Share on other sites More sharing options...
Bbc84 Posted July 3, 2008 Share Posted July 3, 2008 so looks like AVO is a good choice for haveing headroom, AEM to avoid, anthing better than AVO incase I decide to go big? Sometime in the size of FP Green or GT3076 Link to comment Share on other sites More sharing options...
Infamous1 Posted July 3, 2008 Share Posted July 3, 2008 The AVO will be fine for the FP Green or bollt on GT30. If you go with a true rotated GT30t6 you will need a custom rotated fitment intake anyways. Link to comment Share on other sites More sharing options...
PeterJMC Posted July 3, 2008 Author Share Posted July 3, 2008 Went ahead and am going for the 74mm CAI with the WBR FMIC. There goes waiting for the COBB FMIC! Link to comment Share on other sites More sharing options...
Bbc84 Posted July 3, 2008 Share Posted July 3, 2008 The AVO will be fine for the FP Green or bollt on GT30. If you go with a true rotated GT30t6 you will need a custom rotated fitment intake anyways. I think AVO intake it is for me then, FPgreen, i think has better spool, and power diff between the GT30 is not that far apart. Link to comment Share on other sites More sharing options...
PeterJMC Posted July 3, 2008 Author Share Posted July 3, 2008 Anyone know what the tube diameter is for the AVO? Link to comment Share on other sites More sharing options...
