NSFW Posted June 22, 2008 Share Posted June 22, 2008 I ran a couple of cables from my spare tire compartment up to the dashboard today, and ended up going under the passenger seat because I couldn't figure out how to get the center storage compartments out. There are two screws under the rear compartment (where the aux power socket is), and apparently there's something holding it down up front (between the parking brake and the shift lever) but I couldn't figure out how to get in there. Can anyone tell me the secret? Thanks! Link to comment Share on other sites More sharing options...
loak Posted June 22, 2008 Share Posted June 22, 2008 2 plastic "pins" http://legacygt.com/forums/attachment.php?attachmentid=47918&d=1201226207.jpg If you find the part number of these pins, let me know. One of mine is kind of chipped. Link to comment Share on other sites More sharing options...
NSFW Posted June 22, 2008 Author Share Posted June 22, 2008 Thanks! I pushed and pulled thinking that it might unhook from something but it stayed snug. I guess I just need to use more force next time. Link to comment Share on other sites More sharing options...
dragonman586 Posted June 22, 2008 Share Posted June 22, 2008 Did you eat you Wheaties? Really though first you engage the e-brake and then you remove the boot around it.You can accomplish this by just pulling up on the leather (In my case there is always one clip that is stubborn so from the hole made by the other clips being released I put in a screwdriver and jimmy open the last clip) Then I take the two screws out from inside the compartment and just pull while holding somewhere around the front most cup holder. Link to comment Share on other sites More sharing options...
G.T.Subie Posted June 22, 2008 Share Posted June 22, 2008 http://www.edinformatics.com/inventions_inventors/Kool-AidMan.jpg Denial is your best friend Link to comment Share on other sites More sharing options...
NSFW Posted June 22, 2008 Author Share Posted June 22, 2008 ...just pull while holding somewhere around the front most cup holder. Pull up, or pull back? Thanks! Link to comment Share on other sites More sharing options...
DrCloud Posted June 22, 2008 Share Posted June 22, 2008 Geez, I wish I'd known about this. Then I wouldn't have had to use my SawzAll... HPH Link to comment Share on other sites More sharing options...
f1anatic Posted June 22, 2008 Share Posted June 22, 2008 Pull UP and to the RIGHT after you remove the two back screws Link to comment Share on other sites More sharing options...
