mjp0212 Posted June 16, 2008 Share Posted June 16, 2008 last night i started having a little trouble shifting into 2nd. it will shift into gear fairly easy, but unless i put some force into it, it will pop out of 2nd into neutral. this only occurs w/ 2nd gear and there is no slipping at all in any other gears, so i am not really sure what the problem could be. if the clutch was going im assuming it would be slipping in other gears also? been stg2 for a few months now, and this is the first problem i have had with it. any ideas? edit: i have the cobb sts, shifter bushing, and mount. checked the mount and it is tight, nothing seems too worn on the bushings. thought maybe the shifter maybe was hitting something(had that problem at first) but it isnt. i even removed the foam/rubber surround to see if that was maybe the problem, and nothing. stage 2 Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 18, 2008 Share Posted June 18, 2008 check the shifter for clearance again, through the gears and make sure the bolt that connects the shifter to everything else (the fork thing) is tight. the tightness of that bolt on my kartboy popped out of 2nd a few times and i put off fixing it until i got stuck in 1st on the road. obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
SBT Posted June 18, 2008 Share Posted June 18, 2008 ^ what he said. BTW - how many miles on this car? SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
mjp0212 Posted June 19, 2008 Author Share Posted June 19, 2008 like 36,400ish. i will check that stuff again later, hopefully it is just something simple. stage 2 Link to comment Share on other sites More sharing options...
tommypenguin Posted June 19, 2008 Share Posted June 19, 2008 Could be the synchros if your tranny is spitting your shifter out of gear into neutral, if it becomes more frequent you will know shortly. Good luck. Link to comment Share on other sites More sharing options...
SBT Posted June 19, 2008 Share Posted June 19, 2008 like 36,400ish. i will check that stuff again later, hopefully it is just something simple. When was the last tranny service (hopefully somewhere around its 30K normal service interval). If it wasn't done, or you're not sure if it was done, drain the fluid and refill it with straight 75W/90W GL-5 gear oil. If you can put Subaru's Extra-S gear oil in it, even better. It really sounds like someone has put a friction-modifier type gearl oil in your tranny and that's causing the synchros to lose their synchronicity. But, it could also be something more serious, like a bent shifter fork as well, so that's why I recommend starting with the adjustments and the fluid change out first, before you starting looking internally. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
mjp0212 Posted June 19, 2008 Author Share Posted June 19, 2008 last service was the 30k, so it would have been then. i will try out those things this weekend and keep you all posted. it got even worse last night, im practically just driving w/o 2nd gear now stage 2 Link to comment Share on other sites More sharing options...
Max Capacity Posted June 20, 2008 Share Posted June 20, 2008 The tranny is cover under warranty for 60,000 miles, in case you wanted to know. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
