Down pipe for 2003 legacy 2.0gt jdm
LegacyDan
And for your BL model, the turbo should be on the left side of the engine(when you're sitting in the RH driver's seat)? This presumes that you have a JDM with RH drive, and if so, from the driver's seat, the turbo "should" be on the left hand (passenger) side of the car.
IMHO, it would not make sense to have the brake booster, brake and clutch master cylinders right above the hot turbo (and I've not seen this on JDMs before) hence my attempt to clarify the turbo's location from the driver's seat.
If you're standing facing the engine compartment from/at the front bumper, with the hood open, the turbo should be on the right (passenger's side). Is this correct?
SBT
No
http://www.clubsub.org.nz/forum/index.php/topic,22148.msg313524.html#msg313524
all BP/BL - irrespective of L/RH drive have turbos mounted on the RHS
Left and right side of a car is determined by the the seated driver
Current NZ#1 Subaru Tech
Current World #2 Subaru Tech
hi dan
hope this link will help...http://www.hks-power.co.jp/db/muffler_detail.aspx?N_ID=1&F_ID=4944.
JDM downpipe..http://www.hks-power.co.jp/products/exhaust/metalc/metalc.html
thanks for the links to both of them, but neither is for a downpipe for jdm legacy.
HKS do one but its very expensive.
This is a very old thread by the way, i have long since found what i was looking for.
HKS, Zerosports, AVO, Milltek all do one for jdm.
