unlimited6986 Posted May 31, 2008 Share Posted May 31, 2008 Im looking at rims right now but there 17x8 and 42 mm offset. if not what would i need to make them fit? Link to comment Share on other sites More sharing options...
VXCL Posted May 31, 2008 Share Posted May 31, 2008 They will fit, but they are going to stick out of the fenders slightly. Also going to limit tire size slightly since more likely to hit fenders. I have 18x8" rim with a 48mm offset and it sits flush with the fenders. I just cleared my rear fender running a 235/40 after removing the rubber trim. pics here http://www.legacygt.com/forums/showthread.php?t=87979 MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
unlimited6986 Posted May 31, 2008 Author Share Posted May 31, 2008 I got 225/45 17's right now will they fit or rub? Link to comment Share on other sites More sharing options...
VXCL Posted June 1, 2008 Share Posted June 1, 2008 I got 225/45 17's right now will they fit or rub? everytire is diff even though same size rating. my 225/45 winter dunlop m3s are prob diff size then your tire. Also the larger 8" wheel will make them wider then if they are currently mounted on the 7" oem wheel. unless your dropped I cant see them rubbing anything. The tire size is normally fine but thats a pretty low offset. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
unlimited6986 Posted June 1, 2008 Author Share Posted June 1, 2008 Im dropped on s-techs Link to comment Share on other sites More sharing options...
unlimited6986 Posted June 1, 2008 Author Share Posted June 1, 2008 bump Link to comment Share on other sites More sharing options...
EL PAALO Posted June 7, 2008 Share Posted June 7, 2008 probable rubbing. Link to comment Share on other sites More sharing options...
