durbinhunter Posted May 29, 2008 Share Posted May 29, 2008 Hello, I'm new to this forum. I have a new 2008 Legacy Limited. I'm looking to install an aftermarket navigation system (Pioneer, Kenwood with IPOD, SIRIUS, a hard drive, etc) in the dash. Is this possible? What do I need? Thanks!!! Link to comment Share on other sites More sharing options...
mccorry Posted May 29, 2008 Share Posted May 29, 2008 Others have done this... and I'm sure that they will chime in. You might want to search to see what others have done. Welcome to the board. Link to comment Share on other sites More sharing options...
cmc032 Posted May 30, 2008 Share Posted May 30, 2008 i was upset i didnt get a nav so i looked into this. Its very expensive ... over 1000. So i just bought a tom tom for 250 and it works just as good Link to comment Share on other sites More sharing options...
Jefes GT Posted May 30, 2008 Share Posted May 30, 2008 Isn't the factory stereo and the HVAC system inter-connected some how making it very difficult to add an aftermarket head unit? Link to comment Share on other sites More sharing options...
Scooby Fan Posted May 30, 2008 Share Posted May 30, 2008 Get a Garmin Nuvi and put it in the "Cubby" with a remote antenna. I run a Garmin C-340 on the dash.....easy and cheap...all in $300....works as good as any OEM Nav and is totally portable....I have taken it all over the world and used it in rental cars etc........try that with your OEM Nav system Link to comment Share on other sites More sharing options...
Hugo L. Posted May 30, 2008 Share Posted May 30, 2008 Tom Tom One 3rd edition mounted to the left of the gauge cluster. Very discrete. 149$ FTW. Link to comment Share on other sites More sharing options...
Voytech Posted May 31, 2008 Share Posted May 31, 2008 ^ +1 running the same setup... except i paid120 for mine Link to comment Share on other sites More sharing options...
RiffRat Posted June 2, 2008 Share Posted June 2, 2008 Get a Garmin Nuvi and put it in the "Cubby" with a remote antenna. I run a Garmin C-340 on the dash.....easy and cheap...all in $300....works as good as any OEM Nav and is totally portable....I have taken it all over the world and used it in rental cars etc........try that with your OEM Nav system ^+1 I actually have the factory Nav, but was already using a Nuvi 360. Any of the 300 series actually includes a headphone jack and memory card support. I can pre-load MP3's on my unit and connect it through the AUX input and it will interrupt my music to give directions. With this config, the 360 also allows you to use your stereo for your bluetooth hands free speakers for better clarity and, again, it will interrupt your music to handle your call. I only use the onboard when my wife needs to take the Garmin...... Link to comment Share on other sites More sharing options...
08subie3.0r Posted July 22, 2012 Share Posted July 22, 2012 did you ever get this figured out? I'm debating on putting an aftermarket in dash in since my factory one bit the dust. I would just say f it but the clock uses the gps for a time Link to comment Share on other sites More sharing options...
Max Capacity Posted July 23, 2012 Share Posted July 23, 2012 Save your money and buy a tom tom XXL for around $200. Works much BETTER, is easier to use and is portable. Free lifetime updates. work in any car. Use your head...put that cash somewhere it will do more good. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
