Scotty Posted May 14, 2008 Share Posted May 14, 2008 Filled up at the gas station this morning. Drove to work. On the way home from work, I notice the gas guage dropping more than usual. 80 mile commute usually will use less than a 1/4 tank. When got to 70 miles on the trip odometer, it was down to 1/4 tank. It went through 1/8 tank in the last 30 miles home. Decided to fill up again to see how much fuel was burnt, just shy of 5 gallons. That worked out to 16.5 mpg. The trip computer showed 24.0 mpg which is typical since I wasn't driving hard at all. The trip computer has been 1 mpg high. No CEL, no codes, no visible gas leaks. Anyone got an idea where about 1.5 gals went? Link to comment Share on other sites More sharing options...
leggtnut Posted May 14, 2008 Share Posted May 14, 2008 Sh*tty Callifornia Gas is all I can think of. That has happened to me a couple of times when I went with the cheeper gas. Since then, I limit myself to cheveron, shell, 76, or costco and I make up the differance in price with milage. My computer has been just about spot on since day one. And I have a simular commute 70 miles round trip and half is in the santa cruz mountains. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
Scotty Posted May 14, 2008 Author Share Posted May 14, 2008 It only happen today. Should have only burned 3.5 gals to drive 80 miles, NOT 5 gals. 1-2 mpg difference with different fuel is one thing, 8 mpg is not normal. Link to comment Share on other sites More sharing options...
leggtnut Posted May 14, 2008 Share Posted May 14, 2008 agreeded. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
pillboy Posted May 14, 2008 Share Posted May 14, 2008 Puddle under car? It is still ugly. Link to comment Share on other sites More sharing options...
Scotty Posted May 14, 2008 Author Share Posted May 14, 2008 Like I said in the original post. No visible leaks with the engine running. Link to comment Share on other sites More sharing options...
SuperCleanLGT Posted May 14, 2008 Share Posted May 14, 2008 Just a thought but if it is a gas station you don't fill up at very often, maybe their pumps aren't calibrated very well? Link to comment Share on other sites More sharing options...
LongHiway Posted May 14, 2008 Share Posted May 14, 2008 Good ole Ma said something about certain gas pumps in FL registering high - less gas being pumped than the meter reads. Maybe California as well? Link to comment Share on other sites More sharing options...
Spec B Posted May 14, 2008 Share Posted May 14, 2008 Although the chances are slim, I would pull the battery and reflash just to eliminate the possibility that it is ecu related.. Link to comment Share on other sites More sharing options...
Picture_Shooter Posted May 14, 2008 Share Posted May 14, 2008 clean the TB and make sure your air filter looks good. A dirty TB can waste a lot of gas Link to comment Share on other sites More sharing options...
