Jonny Bradtmueller Posted January 19, 2005 Share Posted January 19, 2005 I'm buying Goodridge stainless steel brakelines and Motul RBF 600 brake fluid. I'm pretty sure I need two bottles if the bottles are 500ml. Is this correct? Thanks guys :lol: Link to comment Share on other sites More sharing options...
Kevskate99 Posted January 19, 2005 Share Posted January 19, 2005 I'm buying Goodridge stainless steel brakelines and Motul RBF 600 brake fluid. I'm pretty sure I need two bottles if the bottles are 500ml. Is this correct? Thanks guys :lol:Depends, How quick are you? and do you plan on capping the ends of the lines off while you work on it? You'd be surprised how little fluid is actually in the brake system. Link to comment Share on other sites More sharing options...
Jonny Bradtmueller Posted January 19, 2005 Author Share Posted January 19, 2005 I would assume that I need to replace it all since I'm replacing all the brake lines. How many bottles would it take to fill -if each bottle is 500ml- back up? Thanks Link to comment Share on other sites More sharing options...
Opie Posted January 19, 2005 Share Posted January 19, 2005 If you just need enough fluid to top the system off and bleed it after the install 1 bottle will be plenty. If you are flushing the entire system to change over to the Motul you will need two bottles. Link to comment Share on other sites More sharing options...
Jonny Bradtmueller Posted January 19, 2005 Author Share Posted January 19, 2005 Thanks Opie. I'm going to flush the whole system. I feel better flushing the whole system and not mixing different brands of brake fluid. Plus if I'm replacing all the lines might as well replace all fluid. Thanks again Link to comment Share on other sites More sharing options...
Sands Posted January 20, 2005 Share Posted January 20, 2005 If you are going to flush the whole system, I alternate between ATE Super Blue and the regular ATE stuff. The color change will let you know when you've purged the old stuff. Link to comment Share on other sites More sharing options...
