mvigneau Posted January 18, 2005 Share Posted January 18, 2005 Well I thought you guys would be interested to know I have slowly started my iPod installation. I am in the initial stages of my iPod installation. I have just drawn out my schematic to run 12V 1Amp power using a voltage regulator to keep power cleaner. After testing, I may end up putting on an RFI Filter but that is only if I see problems. I have included the schematic for your viewing pleasure. I am going to cut up the iPod Dock and fabricate it into the ashtray so that I can make a stealth installation. I hope to take pictures along the way and create a write-up of how it was done, but it probably won't be finished for a couple of weeks since I have to wait for parts. Although I have received the following parts: 1.) Voltage Regulator MC7812 2.) Capacitors (.33µF and .1µF) 3.) FM Modulator 4.) iPod 5.) iPod Dock Waiting on the following parts: 1.) Antenna Connectors 2.) LEDs (I like lights). No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
fbi012 Posted January 18, 2005 Share Posted January 18, 2005 nice stuff, keep us updated. Link to comment Share on other sites More sharing options...
dbwillis Posted January 18, 2005 Share Posted January 18, 2005 Nice schematic, good luck with the install ! Link to comment Share on other sites More sharing options...
DEI99662 Posted January 18, 2005 Share Posted January 18, 2005 Be sure to take those pics as you go. Link to comment Share on other sites More sharing options...
c_hunter Posted January 20, 2005 Share Posted January 20, 2005 Hey Mike, so are you an EE? We could use some additional EE expertise to finish working out the direct line in solution centerpunch came up with (sticky at the top of the interior/audio forum). Basically, we need a clean and safe way to switch sources between an aux-in and the CD when hijacking the ribbon cable that goes to the amplifier in the stock radio. I have worked out all the other details on connectors/etc... but the EE level stuff remains to be completed. If someone can pitch in on that, we can all get a nice clean dependable direct line in and stop messing with the modulators. Craig Link to comment Share on other sites More sharing options...
mvigneau Posted January 20, 2005 Author Share Posted January 20, 2005 Unfortunately I am not an EE. I meddle in the arts of electronics but no where near the expertise needed for that. I work at a place that has them, but I would need someone to donate their radio so that we could actually take it apart and try to fabricate something because I don't want to give up on mine. If we use your radio, you will receive the connector free of charge. But that is if they agree to do something. Can you explain to me what you need, I have read the iPod post, but if I could get the information in consolidated form (with pictures helps) I could explain it to a couple of EE's here. They may be able to construct something without the radio but I would need to know the size of the ribbon cable and all of that stuff. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
mvigneau Posted February 8, 2005 Author Share Posted February 8, 2005 Alright...I am so close I can taste it (or is it hear it). I am only waiting for the antenna connection pieces to make an antenna adapter. Everything is done and I have started writing up my installation instructions as well as sorting/editing the pictures. I am VERY happy with the way it came out. I have made it easy to adapt to other inputs in case someone comes out with direct RCA inputs without having to modify the vehicle. Anyways, here are 3 pictures of the finished product. The electrical tape is there to protect the console from getting scratched up. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
meatwad Posted February 8, 2005 Share Posted February 8, 2005 Thats some good fab work there man! Is that fiberglass? Though I am sure you will post them when it is complete in the car, I am looking forward to the final pics! Link to comment Share on other sites More sharing options...
mvigneau Posted February 8, 2005 Author Share Posted February 8, 2005 Thanks...Actually I just used bondo...bondo...bondo and more bondo. It is slow and of course I see all of the defects, but am very happy with it. I hope to have it done this week (as long as I receive the antenna parts). No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
Plaz Posted February 8, 2005 Share Posted February 8, 2005 Have you already tested out your circuit? I'm wondering if you can really get a clean 12V output under load. I would have expected that you'd need 14V or more to get a 7812 working right. Note that you can make a 12V regulator from a 7805 as shown in the link below: http://www.rason.org/Projects/regulator/regulator.htm Link to comment Share on other sites More sharing options...
mvigneau Posted February 8, 2005 Author Share Posted February 8, 2005 Yes...I saw that one while searching for a regulator. I liked how the 7812 was a constant voltage and not a variable. The iPod has charged with 10V output using a test setup at home of 12VDC Input. You are correct, You need to have 14V input to have a 12V output. But your vehicle while running (alternator) usually outputs at around 14.4V and I have seen it go up to 18V. I could have used either regulator, but it doesn't really matter as long as itworks. A voltage regulator is a good idea because there can be spikes in a car's voltage that go up to 20kV. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
eamiller Posted February 8, 2005 Share Posted February 8, 2005 It might also be a good idea to put voltage clamps on the input side as well as a reverse battery protection diode. Having been involved in a couple of EE automotive grade electronics designs, these are essential for longevity and protection. Jump starting is a nasty thing for electronics, and consumer grade can't handle it. Link to comment Share on other sites More sharing options...
mvigneau Posted February 8, 2005 Author Share Posted February 8, 2005 But I am using the cigarette lighter circuit/fuse so wouldn't that have a reverse battery protection diode already? I didn't think I would need this because I was wiring to the cigarette lighter, but if it doesn't then I will definitely put one in. As to the voltage clamps. I don't think I need them because the input has a capacitor to catch any unnecessary/rogue voltage/spikes and also the input goes upto 30v. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
mvigneau Posted February 15, 2005 Author Share Posted February 15, 2005 I finally received the parts from Hirose!! Months of waiting and they finally arrived in my hands. Well I have made the connections onto my FM Modulator. I will finally be able to install it and have taken tomorrow off to actually do it. It took me 3 tries to finally make one of the connections (the one going into the cars antenna connection). So I am able to make 6 other connections for people since I want to make sure that I have at least one. After my installation, I will offer people the ability to buy a connection. Here are some more pictures to wet your appetite. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
mvigneau Posted February 15, 2005 Author Share Posted February 15, 2005 Here is the final product. I am very happy with the looks. Unfortunately because it is going through FM, the sound is not the greatest, but it's better than nothing. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
Alex1 Posted February 15, 2005 Share Posted February 15, 2005 niice... but what about the ac controls.. im sry but seems liek a dumb place to mount it... cuz ude hafta take it out of the dock to play with the fan speed and stuff good work tho Link to comment Share on other sites More sharing options...
mvigneau Posted February 16, 2005 Author Share Posted February 16, 2005 I usually set the temp before since it doesn't need to change that often. Plus I still have access to the auto temp setting on my side as well as full control on the pass side. I don't really use the manual control that much so it wasn't a big deal. Plus I can remove the iPod and it will continue playing and so I can easily redock it and continue listening. Minor issue for me. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
Ken S Posted February 16, 2005 Share Posted February 16, 2005 Great job! I really like how you integrated the dock into the ashtray. Very nice touch. I wonder if a standard iPod would be able to fit the same way. Ken Link to comment Share on other sites More sharing options...
mvigneau Posted February 16, 2005 Author Share Posted February 16, 2005 It would be a tighter fit, but doable and no LEDs (although I wouldn't recommend them since they are so bright) or at least get like 100mcd instead of the 6000mcd that I got. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
