executor485 Posted May 5, 2008 Share Posted May 5, 2008 Ok, I have been searching for a while and still havent found the answer(s) I'm looking for... But I'll slap on my flame suit just in case... lol I just got an AP V1 from a member here on the forums. IIRC, it has a stage 2 map from TDC on it... Could be wrong though, I havent plugged it in yet to check... So, here's the deal. I know that the maps are built specifically for the previous owner's mods... So lets say we both have/going to have the same mods. I dont have the mods on yet, but I'm going to put them on this weekend... But I want to use the AP until that time. So I can run stage 1 until I get the mods done and then go stage 2. -My question is: Do I need to load a base map that is stage 1 and then re-flash when I go stage 2 and do a stage 2 base map(really dont look forward to wasting 20-30 min each time re-flashing... lol)? Or can I run a stage 2 base map, and then just run a stage 1 realtime map until I can put the mods on this weekend? Thanks for the help. BTW, mods are as follows: Perrin Air Filter STi Catless Up Pipe Gutting OEM Down Pipe Silencer Box Removed Hogzaust FTW! If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
f1anatic Posted May 5, 2008 Share Posted May 5, 2008 Either have patience until you put your Stage 2 hardware OR Install Stage 1 maps - BASE and REAL time drive it like that and when you go Stage 2, then you flash again the base stage 2 and then the real time stage 2. Why do you want to risk anything for 30 minutes ? I am surprised you are not asking whether you should just install Stage 2 base map now and flash the factory settings real time ? Have patience, do the mods in the proper order. Link to comment Share on other sites More sharing options...
pierce88 Posted May 6, 2008 Share Posted May 6, 2008 Or can I run a stage 2 base map, and then just run a stage 1 realtime map until I can put the mods on this weekend? He did ask that. And you should be fine loading the stage 2 base map and running the stage 1 real time. -Pierce Link to comment Share on other sites More sharing options...
