johnboi85 Posted April 26, 2008 Posted April 26, 2008 i installed invidia downpipe and perrin uppipe. both catless. at first i didnt use new gaskets. when i first started it up, i heard a tinny exhaust note. kind of like a ticking noise coming from the downpipe. i thought maybe there was an exhaust leak so i put in the new gaskets for the uppipe, downpipe, and manifolds. started it up again and same thing. anyone else having a tinny exhaust note coming from teh downpipe? there are no exhaust leaks whatsoever. anyone
johnboi85 Posted April 26, 2008 Author Posted April 26, 2008 i'm running a greddy evo 2 cbe. so no one has this problem?
BigBad Posted April 26, 2008 Posted April 26, 2008 You've stumped me. With an evo2 and catless down /up you should be getting alot of sound out of that system.
biggggant Posted April 27, 2008 Posted April 27, 2008 i think he meant tinny=metalic rattle not tiny=small lol
johnboi85 Posted April 27, 2008 Author Posted April 27, 2008 yes a metallic noise. so far i deem it normal unless someone can prove to me otherwise haha
Silverstar Posted April 27, 2008 Posted April 27, 2008 I had a cobb heat sheild that would occasionally make a metallic noise under part throttle. Found that a screw had worked itself loose. Noises are tough to diagnose. They are even tougher when the noises are described instead of heard. Any chance you can get a sound clip? These cars make alot of noises. Most of them are normal. Determining which are normal and which are abnormal can be difficult.
