joneric Posted April 12, 2008 Share Posted April 12, 2008 my 05 GT wagon has this annoying howling noise inside. i thought it was the tires and just changed to conti extreme contacts but the noise is still there. it's present in all gears, bad on the highway, and makes it difficult to enjoy the sound system. the car didn't always do this. i remember thinking it had a quiet cabin at one time. it started around 50,000 miles. any suggestions on what the problem might be? Link to comment Share on other sites More sharing options...
vern Posted April 12, 2008 Share Posted April 12, 2008 Wheel bearing going bad? Link to comment Share on other sites More sharing options...
Opie Posted April 12, 2008 Share Posted April 12, 2008 Wheel bearing going bad? +1 Link to comment Share on other sites More sharing options...
gugarci Posted April 12, 2008 Share Posted April 12, 2008 yep, wheel bearing. Link to comment Share on other sites More sharing options...
djkxgo0k Posted May 11, 2008 Share Posted May 11, 2008 i just started having this same exact problem. i'm at 51,000 miles. did you ever figure out what's wrong? is it the wheel bearing? how would you fix it? Link to comment Share on other sites More sharing options...
Opie Posted May 11, 2008 Share Posted May 11, 2008 i just started having this same exact problem. i'm at 51,000 miles. did you ever figure out what's wrong? is it the wheel bearing? how would you fix it? http://www.thel7.com/TSB/03-58-08.pdf Link to comment Share on other sites More sharing options...
djkxgo0k Posted May 12, 2008 Share Posted May 12, 2008 ah, thanks! much appreciated =] Link to comment Share on other sites More sharing options...
