ean611 Posted April 14, 2008 Author Share Posted April 14, 2008 Ok, decision made. Just ordered 8 inch Image Dynamics 2Ohm DVC sub. Image Dynamics claims their sub will operate quite well free-air in a rear deck. The tech on the phone, a former installer, had done stuff similar with good results. Hopefully, the sub will be here from Woofers ETC shortly. Thanks ItalynStylion for the tip! I'll post pics in my install thread when I get the sub and install it. Now for a line driver....Wonder if there are any good cheap ones.... Link to comment Share on other sites More sharing options...
ItalynStylion Posted April 14, 2008 Share Posted April 14, 2008 Excellent....keep us updated Link to comment Share on other sites More sharing options...
MiniStiGuy Posted April 15, 2008 Share Posted April 15, 2008 Subscribed OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ShadowImg Posted April 16, 2008 Share Posted April 16, 2008 When I examined this on my 08, I got the impression that the sub actually mounted in from the top, not the bottom. Has anyone disassembled the rear deck to find out how it's supposed to actually sit in there? That might affect the mounting depth -- otherwise it's gonna be real tight. Link to comment Share on other sites More sharing options...
ItalynStylion Posted April 16, 2008 Share Posted April 16, 2008 ^From the pictures that have been posted it would seem the sub mounts from the top. I don't know because I have yet to buy a LGT. Enclosure design will be tricky but that is why I suggested a woofer that does well IB. If he mounts it IB and he likes it the depth issue of an enclosure will be irrelevant Link to comment Share on other sites More sharing options...
ShadowImg Posted April 16, 2008 Share Posted April 16, 2008 ^From the pictures that have been posted it would seem the sub mounts from the top. I don't know because I have yet to buy a LGT. Enclosure design will be tricky but that is why I suggested a woofer that does well IB. If he mounts it IB and he likes it the depth issue of an enclosure will be irrelevant Yup, I'm actually concerned about just the speaker itself clearing, enclosures aside. There's very little room there. Link to comment Share on other sites More sharing options...
chikmagnet Posted April 16, 2008 Share Posted April 16, 2008 you can mount the sub on top or bottom depending on depth of the sub remember to have enough clearance on top for excursion. -Josh Herrera -2007 DGM OBXT Link to comment Share on other sites More sharing options...
ean611 Posted April 17, 2008 Author Share Posted April 17, 2008 Well, according to UPS, my 8 inch Image Dynamics Sub arrives Friday. Also, according to Image Dynamics Tech Support, their sub will work well in an infinite baffle. I'll post pics and details when I have the thing installed. Link to comment Share on other sites More sharing options...
ItalynStylion Posted April 17, 2008 Share Posted April 17, 2008 remember to have enough clearance on top for excursion. Oh yeah, that's very important. Don't forget to check that out. Link to comment Share on other sites More sharing options...
ean611 Posted April 19, 2008 Author Share Posted April 19, 2008 Ok, tried the install the Image Dynamics sub. One of the tension bars for the trunk moves right into the magnet. I measured, and unless I can do something about the the trunk tension bar (remove one of them?), I have 3 inches of clearance. I'm going to have to either figure out a way to A) Remove one of the two trunk tension bars (I'm not sure that is even a good idea) or B) find an alternate location. Link to comment Share on other sites More sharing options...
chikmagnet Posted April 19, 2008 Share Posted April 19, 2008 same location just remove the tension bars and go to a spring or shock setup. -Josh Herrera -2007 DGM OBXT Link to comment Share on other sites More sharing options...
ean611 Posted April 20, 2008 Author Share Posted April 20, 2008 chikmagnet, I'd like to do that, but i have no clue how to do that....Any ideas? Link to comment Share on other sites More sharing options...
phenryiv1 Posted April 21, 2008 Share Posted April 21, 2008 So 3" is your max depth? Now might actually be a time to look specifically at shallow-mount subs. I know that tang band makes one, but I don't know if it works in free-air... Edit: It is a 10" http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-862 Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
phenryiv1 Posted April 21, 2008 Share Posted April 21, 2008 Other possibilities (based solely on depth): http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-376 http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=297-040 http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=297-310 http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=297-066 Another option is a 7" woofer with a mounting ring: http://www.partsexpress.com/webpage.cfm?webpage_id=3&CAT_ID=49&ObjectGroup_ID=572 Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
ItalynStylion Posted April 21, 2008 Share Posted April 21, 2008 Could you make a 1.75" top mounting ring to raise the sub up off the metal? That would give you enough clearance since the sub has a depth of 4.75" Is there enough room under the rear deck? Link to comment Share on other sites More sharing options...
ItalynStylion Posted April 21, 2008 Share Posted April 21, 2008 On the other hand, my is300 had trunk bars and I fabbed up a shock setup that opens the trunk. It honestly wasn't that hard. Just take some measurements, find a good solid mounting point, and drill some holes and cut the old bars out. Link to comment Share on other sites More sharing options...
chikmagnet Posted April 21, 2008 Share Posted April 21, 2008 all you really need is 4 eye hooks and 2 springs -Josh Herrera -2007 DGM OBXT Link to comment Share on other sites More sharing options...
ItalynStylion Posted April 21, 2008 Share Posted April 21, 2008 all you really need is 4 eye hooks and 2 springs I don't know these parts by name; can you post pics of what you are talking about? Have you deleted the trunk bars? I was pretty much the only person to do it in the IS300 world but I'm curious if you LGT guys have a decent solution that everyone already does. Link to comment Share on other sites More sharing options...
phenryiv1 Posted April 21, 2008 Share Posted April 21, 2008 I was thinking about this a bit more today, and if yo uwere to do this, you would obviously want to deaden the rear deck very well. On top of this, you would want to use MDF and make a mounting ring to mount on the underside of the deck (cut to fit the flat area on the underside of the rear deck). This would give you a more solid mounting point than just screwing the speaker into the metal skin. You could sandwich deadening between the ring and the rear deck. Regarding the idea above to make a ring on the top, you could fab a spacer ring on the top, then finish it in fiberglass or bondo and paint it to match the rear deck. It would also allow you to have a flush-mount grille like http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-424 or http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5727 Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
ean611 Posted April 21, 2008 Author Share Posted April 21, 2008 I appriciate all the advice. I've pretty much surrendered my desire for the rear-deck sub in exchage for two Fiberglass enclosers in the left and right pockets. That space isn't useful for trunk stuff anyway. I'm going with 2 ID8V2s, as they take little air, and 2 is better than 1. (2Ohm to my Amp). Link to comment Share on other sites More sharing options...
