outbacksam Posted April 10, 2008 Share Posted April 10, 2008 change all the tires at same time,or can I replace 2 at a time AWD legacy outback TY in advance Link to comment Share on other sites More sharing options...
blackfang Posted April 10, 2008 Share Posted April 10, 2008 change all the tires at same time,or can I replace 2 at a time AWD legacy outback TY in advance All 4 of them. You can not have more than 1/4" difference in circumference(note I did not say 32nds which most dumbass tire shops try to tell you) of all the tires. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
rjundi Posted April 10, 2008 Share Posted April 10, 2008 change all the tires at same time,or can I replace 2 at a time AWD legacy outback TY in advance It depends on the difference in wear between the new single tire vs the 3 others. The average of 3 must be within 1/4" circumference(distance around measured at same spot at proper pressure) of the new tire. Link to comment Share on other sites More sharing options...
outbacksam Posted April 11, 2008 Author Share Posted April 11, 2008 just wanted to change the 2 front tires they are all kinda low. the outer ware bar is up is that 1/4 in dia or radious( one side) Link to comment Share on other sites More sharing options...
krzyss Posted April 11, 2008 Share Posted April 11, 2008 just wanted to change the 2 front tires they are all kinda low. the outer ware bar is up is that 1/4 in dia or radious( one side) neither circumference is the magic word. Krzys Link to comment Share on other sites More sharing options...
f1anatic Posted April 11, 2008 Share Posted April 11, 2008 He does not have LSDs so he probably will be fine with replacing 2 at a time. Link to comment Share on other sites More sharing options...
SSN666 Posted April 11, 2008 Share Posted April 11, 2008 "circumference is the magic word." Not necessarily related, but once I had A SAAB 900 where uneven wear changed the circumference of the fronts enough that it caused the car to 'pull' slightly in the direction of the tire. Link to comment Share on other sites More sharing options...
OhBe1 Posted April 12, 2008 Share Posted April 12, 2008 Doesn't he have an LSD in the middle? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
