CodyItaliano Posted April 7, 2008 Share Posted April 7, 2008 my subaru is soon to be out of the shop. its an '05 LGT with Cobb stage 2 tuing. it will have brand new OEM subaru clutch and flywheel. my question is what should i do to break it in correctly, to prolong the life in the long run? i would think, dont drive it for extended periods at high speeds, like on the freeway. dont dump the clutch. but being that it does have more power than a stock programed engine, i dont know how i shold treat it. for example, how much slippage should i allow in first gear? i really just dont want to need a new clutch again for some time. i dont know if i'm worring too much or if this is a good thing to think about. Link to comment Share on other sites More sharing options...
Beanboy Posted April 8, 2008 Share Posted April 8, 2008 Doesn't matter what you do when the clutch is fully engaged. Lots of urban driving will help the clutch break in sooner. Obviously, don't launch hard or slip the clutch at all for roughly 500 miles give or take. Anything over a couple of seconds would be considered slipping. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
CodyItaliano Posted April 9, 2008 Author Share Posted April 9, 2008 ok. i live in the city. mainly driving in residential areas. so i guess i'm good to go then. Link to comment Share on other sites More sharing options...
Beanboy Posted April 9, 2008 Share Posted April 9, 2008 Ayup. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
qikslvr Posted April 13, 2008 Share Posted April 13, 2008 Just give it at least 500 miles before you start driving it hard. Try not to spin it up off the line, slam gears or launch it. Other than that you should be good. Let's kick this pig! Link to comment Share on other sites More sharing options...
