mschmidt Posted April 6, 2008 Share Posted April 6, 2008 All, Sorry to post here but I have a problem after a Megan Coilover install on my 05' LGT Sedan. I need some traffic in this post to get this resolved ASAP as I need my car! Everything seems good except for the driver’s front coilover. When going over bumps it clunks really loud. It is coming from the top hat area. The one noticeable thing that does not seem right is that I cannot tighten down the top nut on the coilover shaft. It just keeps spinning! The passenger side tightened down no problem and I do not have any clunks over there. These are used coilovers that did not come with the wrenches. I used some c-clamps to tighten everything up for now (except the top nut of course). Please help, specific questions below: 1) How do I tighten down the top bolt when it just keeps spinning with the shaft? 2) Is it safe to drive? I assume the clunk is due something being loose and I hate to wear something out of damage something further. Below is a link to my post with more info on the install. http://legacygt.com/forums/showthrea...99#post1818199 Link to comment Share on other sites More sharing options...
LittleBlueGT Posted April 6, 2008 Share Posted April 6, 2008 I would use an impact wrench on the top nut. DON'T SPIN it, just give it a couple good jabs, it should tighten up nicely. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
MOMSWGN Posted April 6, 2008 Share Posted April 6, 2008 +1 on impact wrench. If you don't have air tools, then a spanner and box wrench. Good luck. Link to comment Share on other sites More sharing options...
ehsnils Posted April 6, 2008 Share Posted April 6, 2008 Clunking noise can also be from a bad shock absorber. So if tightening the nut doesn't work you may have a bad shock. A problem may be that this clunking has destroyed the threads if you were unsuccessful in tightening it in the first place. Link to comment Share on other sites More sharing options...
mschmidt Posted April 6, 2008 Author Share Posted April 6, 2008 I was able to hold the shaft with a 5mm allen wrench to get it tight enough to not clunk under normal driving. Though, I can get just about every corner to clunk when I go over a sharp edge. As well, I can spin the shaft on all four top nuts... so they really aren’t tight enough correct? Link to comment Share on other sites More sharing options...
mschmidt Posted April 6, 2008 Author Share Posted April 6, 2008 This thread can be closed... I will continue with the original thread. Sorry for posting two threads... I was in a jam though! Sort of still am... Link to comment Share on other sites More sharing options...
