LGTBee Posted June 30, 2009 Share Posted June 30, 2009 This was a great write up- I ended up with the tape option and it drastically reduced the sound my chime was making. Thanks for posting this up! Link to comment Share on other sites More sharing options...
RShaw Posted July 1, 2009 Author Share Posted July 1, 2009 No problem, im just glad i could finally contribute something semi useful. Haha Link to comment Share on other sites More sharing options...
eaumack Posted July 31, 2009 Share Posted July 31, 2009 Just de-solder it. Less chance of messing something up, and you can put if back if you choose (to sell the car, perhaps). De-soldering the chime bell seems like the most intelligent way of getting rid of ALL the f**in' chimes without cutting wires. How do you de-solder the bell? Can you provide more info on that? I want to attempt this but don't have too much skills when it comes to modifying delicate electronics. My apologies if this is really obvious, I haven't had a look at it yet, just trying to gage the difficulty of this mod before i dive right into it. Link to comment Share on other sites More sharing options...
bheinen74 Posted November 9, 2009 Share Posted November 9, 2009 tinkerbell must go bye bye soon for me too. Link to comment Share on other sites More sharing options...
Zephrant Posted May 30, 2011 Share Posted May 30, 2011 I just tried to go though this today- I've done a lot of electronics work, but I could not get that black box apart without destroying it. I even warmed it up in the oven for a 1/2 hour... (140 degrees). I ended using a forstner bit in a drill press to drill a 1/2" hole over the top of the speaker, then using a 1/4" drill to drill out the speaker. I put black tape over the hole I cut, and since it is mounted with that hole against the column, no-one will ever know unless they pull that module out. But the no-chimes was worth it! Link to comment Share on other sites More sharing options...
RustyShackleford Posted June 6, 2011 Share Posted June 6, 2011 De-soldering the chime bell seems like the most intelligent way of getting rid of ALL the f**in' chimes without cutting wires. How do you de-solder the bell? Can you provide more info on that? I want to attempt this but don't have too much skills when it comes to modifying delicate electronics. My apologies if this is really obvious, I haven't had a look at it yet, just trying to gage the difficulty of this mod before i dive right into it. Wow, holy late-answer, Batman ... Sorry about that, but hope this helps someone. If you don't have any idea how, maybe you shouldn't try; it would SUCK to mess up the module, I think it's pretty expensive to replace. But the method is to heat up each of the pins on the chime bell where they stick through the circuit board - so you'd be on the back side of the board. Heat each one up and use either a "solder sucker" or a special piece of braided copper wire designed for this purpose. Thereby removing enough of the solder from each pin so that they are loose. Do you maybe have a buddy, or a friendly shop, that does this kind of work ? It will take about 2 minutes for a person with the proper skills and equipment. I'd do it for you myself if I could. Rusty HATES those effin' chimes !! Link to comment Share on other sites More sharing options...
Zephrant Posted June 7, 2011 Share Posted June 7, 2011 With the proper soldering iron and a little skill, you can just heat up both pins at once and pop it right off. Find someone who knows electronics soldering and it'll take less than 15 seconds to remove. If you've never soldered electronics, you might want to get some help. Too much heat on the board is bad. More than 20-30s of heat could be too much. Of course, I couldn't even get in to my case to unsolder it... Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 14, 2011 I Donated Share Posted June 14, 2011 What is this module CALLED? I bet there is a way to snip one of the wires rather than opening the box up and messing with the chime. I'd be happy to experiment, but I need to know what the box is/does in order to look for wiring diagrams in the FSM. Link to comment Share on other sites More sharing options...
RustyShackleford Posted June 15, 2011 Share Posted June 15, 2011 I believe it is called the "integrated module". Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 15, 2011 I Donated Share Posted June 15, 2011 I believe it is called the "integrated module". I did find out that it is the BIU (Body Integrated Unit). The chime is integrated into the circuitry inside, but if you want to disable the seat belt warnings, you can cut the black/blue wire right next to the clip on the I84 connector, and the red/white wire right below it. Alternately, you can cut the black/blue wire on the underside of the driver's seat, and one of the connectors going into the Occupant Detection Control Module (the 2-pin oval one) can actually unplug and that should take the seat belt sensor out of the equation (it should look like it's always buckled). With that said, snipping the red/white wire is probably safer, because that's the seat belt signal coming from the Airbag Control Module to the BIU, so the ACM will still think the buckle is not fastened. I am personally going to put in a DPST switch to turn off the seatbelt warning for both seats by switching the black/blue and red/white wires. BTW, this is all based on the FSM. I haven't taken a look in my car yet. Link to comment Share on other sites More sharing options...
Bimmer Posted June 16, 2011 Share Posted June 16, 2011 ... if you want to disable the seat belt warnings, you can cut the black/blue wire... Right, but as the title of the thread says, the question is "how to completely get rid of ALL chimes..." It wasn't just the seat belt chime I wanted gone, it was also the keys-in-the-ignition chime. Really, opening the module and popping the chime off the circuit board is probably the least intrusive and most easily reversed way to do this. Once you put the module back together, there's no sign that you tampered with it, and if you ever want the chime back, then you could solder the chime back onto the circuit board. (You could, I couldn't, because mine went right in the trash.) Link to comment Share on other sites More sharing options...
RustyShackleford Posted June 16, 2011 Share Posted June 16, 2011 Count me among the numbers of those favoring removal of the chime device from the BIU circuit board - especially as opposed to snipping wiring. Link to comment Share on other sites More sharing options...
cjlgt06 Posted March 19, 2012 Share Posted March 19, 2012 Hey guys I just did this mod....but after putting it all back together I get a check engine code p0600. I pulled the battery and charged it and put it on but the code is still going and wont let me start my car. Any body have any suggestions?Please help guys Link to comment Share on other sites More sharing options...
cjlgt06 Posted March 20, 2012 Share Posted March 20, 2012 Cmon guys I know you guys can help find me a solution!! Did I screw something up? Link to comment Share on other sites More sharing options...
